Results 1 to 18 of 18
Thread: Equipment Upgrade Quote
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Here's the first quote I received on the equipment upgrade we've been discussing here: equipment-upgrade-with-easy-touch-t50807.html
    Pentair EZTOUCH8 IC40 $1,601.00
    CVA Actuator 100.00
    Intelliflo VS3050 Pump 949.00
    3-Port Jandy Valves x4 267.80
    1 Jandy Check Valve 90 Degree 60.00
    Misc, PVC, Fittings, Conduit wire, Paint 85.00
    Promo Energy Rebate (200.00)
    Wireless 8 Controller 560.00
    SUBTOTAL $3,422.80
    SALES TAX 277.25
    LABOR 750.00
    TOTAL $4,450.05
    I think the hardest part of this quote for me to swallow is the labor, when I'm sure I could get through it myself. I'll ask them about the 3 year warranty thing as well. That would make the labor worth it. I think I might have to purchase a filter to qualify. I just noticed they left off the 2 Intellibrites as well. I'll update later.
    After July 31, I lose the Promo Energy Rebate. I'm not if this is a utility company or pool store's rebate. NV Energy's site says their rebate on pool pumps has been suspended. I'm not sure if the pool store knows this yet.
    Thanks....Bill
    PS: I worked on the formatting to make the quote line up but gave up. Sorry.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Equipment Upgrade Quote
    I just talked to the dealer. He's going to update the quote with 2 Intellibrites and an IntellipH. He said I'm buying enough that they would honor the warranty although I'm not getting a filter.
    38,248
    I will just point out that most of the prices are a little high ... especially for not already including the labor.
    All your Jandy valves are about $50 each online delivered.
    And an Intermatic actuator can be had for $60 online.
    There have been Intelliflo for less than $900.
    The EZtouch and controller might be about 10% high as well.
    There are times it is cheaper to buy the equipment yourself and give up the rebate than to have to buy from a "authorized dealer" to get the rebate. Although there is also the question of if you need someone to install it for you ... they may not if you do not buy from them.
    Just a heads up.
    May 2011
    Orange County, CA
    696
    Not a bad price on most of the equipment, except the Jandy valves. I'm surprised they will honor the three year warranty because Pentair told me that they will only do this with, according to an email from them, with two major equipment upgrades plus something like an Intellibrite, and they all have to be purchased on the same receipt. I didn't know this going in, and despite purchasing two Intellibrites, an Intelliflo and an EasyTouch 8 with the IC60 SWCG over a period of about 3 months, they will not extend the three year warranty to my purchases (which I personally think is very lame now that I truly understand their policy). In any event, I think the $750 installation is worth it if you can get the guarantee on the three year warranty up front. Setting up the plumbing on the pump and valves, and then installing the EasyTouch is going to be time consuming. I'm all for DIY, but I'd go for the deal you've been quoted just to save headaches and have the extended warranty.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Revised quote including the Intellibrites and IntellipH.
    CVA Actuator 100.00
    Intelli PH Controller 510.00
    Intellibrite Spa light 100' 453.00
    Intellibrite Pool Light 100' 554.00
    SUBTOTAL $4,939.80
    SALES TAX 400.12
    LABOR 750.00
    TOTAL $6,089.92
    He left the labor the same although installing 3 additional pieces of equipment. He did say that I would have to drain the pool as they don't pull lights with water in the pool.
    I understand I can get every piece of equipment cheaper online. Factoring in the $200 rebate, I figured it's costing about $200-$250 more. However, I'm establishing rapport with a local business and will have a 3 year parts/labor warranty. Overall, I could probably do it myself for $1000-$1500 less. I'd rather the 3 year warranty and not have to worry about doing it myself. I'm pretty handy, but I'm a perfectionist, meaning it would take me forever!!! Thanks for all the replies.
    Bill
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    If you have an iPhone or computers consider getting the Screenlogic instead of the wireless controller.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    There really wouldn't be a need for both, correct? Is Screenlogic better in terms of programming and such?
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I just checked out the user's manual on ScreenLogic. Interface looks much better for programming.
    Lershac: Are you using ScreenLogic2?
    May 2011
    Orange County, CA
    696
    Or, consider the Autelis Intellitouch controller. This will soon be able to control Easytouch systems, is cheaper, and offers support for any web browser for remote control (e.g. Android, etc), not just iPhones. It acts as a web server that controls the Intellitouch/Easytouch via its RS485 communications port.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Yes but am going to look into what craigmw brings up here as well... Link?
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I sent the "pool guy" an email saying I'd rather have the ScreenLogic2 with wireless adapter kit instead of the ET8 Wireless Controller. His reply, "That product is discontinued." Is there any truth to that whatsoever? Why would he tell me that? Seems as though Pentair pushes it pretty hard.
    EDIT: Also, kinda raises a flag about the whole thing.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Wow. You couldn't tell via their website, still very much being sold.
    Check out A1poolparts.com. It's where I got all my automation equipment. They occasionally have great discount specials ( I bought everything from them 20% off their list prices with one).
    Possibly he doesn't sell it or know how to install it?
    If you have any experience with electrical, they are intimidating, but not difficult to install and program yourself. But it would be a big undertaking for someone to jump into with both feet. I did it. Very intimidated but I bulled through it successfully. The guys on the forums here were of great help.
    May 2011
    Orange County, CA
    696
    Here's the link:
    http://www.autelis.com/pool-control-for ... touch.html
    The Easytouch is still in the works, but not far behind hopefully. I don't think this is as full-featured as the Screen Logic 2, but has the advantage that its fully self-contained. It serves as the web server, and you can control special functions with HTML code through it. If you have an HA system with a web server, it is possible to bridge the HA with the pool automation using the Autelis. I'm setting ours up over the weekend, at least for some testing.
    May 2011
    Orange County, CA
    696
    Also, I doubt that Pentair would be discontinuing their Screen Logic interface. It's only been around for a little over a year or so.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I think I'll just go with the ET8 Wireless controller for now. It'll save me about $500, I think. I can always add the ScreenLogic later, right? Will it work with the ET8 wireless controller if their both wireless from the panel?
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    I'm about to give them the go to do the work. Should I pay for everything upfront? Or should I just pay for the products, then pay for the labor after the install? I've heard horror stories with pool contractors being paid everything up front. Thanks.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    One more question about the pump. I had initially only asked for a quote on the Intelliflo pump. He gave me the quote, and told me "The model number is for the 4x160 Plus #011018." The quote above with the rest of the equipment says the VS3050. Isn't that the older one?
    I would never pay anyone 100% upfront. The most I would do is 50% upfront. Anyone that requires 100% payment is either 1. Not confident in their work or 2. hurting for money in a struggling business and personally I would not want either doing work for me.
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
