Results 1 to 7 of 7
Thread: Help! Soapy water ... Saltwater pool
    Jul 2012
    Bismarck, North Dakota
    5
    New to pool world and learning a lot... Sometimes painfully! Have index above ground 16 foot pool with salt water system. Been awesome and low maintenance until two weeks of 100 degree weather. The water was looking cloudy and a tint of green... And water boatmen moved in. I read on a forum that algaecide would kill the bugs and take care of green algae. Added 16 oz of algaecide 50% ... Which I've discovered was too much!!! Killed all the bugs and water is clear but now the water feels and taters soapy. When kids splash... Makes small soapy bubbles.
    Do I need to drain some water? If so how much.
    I tested it and the alkalinity is high. Though I don't feel confidant with my skill at reading the strips!!!
    Wishing I wouldn't have added the agaecide!!!
    Hardness 100
    Free chlorine strip is white ... Does that mean zero????
    Ph 6.4 to 6.8
    Alkalinity 240. ( end color on strip)
    Cy acid light yellow. Zero????
    Scrapnmama
    5,000 gallon
    Intex 16' Above ground
    Salt Water Generator with Intex cartridge filter
    38,285
    Re: Help! Soapy water ... Saltwater pool
    Welcome
    It was the algaecide that caused your foam ... as you now hopefully realize, there is no need to that stuff ... just adequate FC.
    You can not trust the test strips ... you should invest in one of the recommended test kits.
    Hard to really give advice based on the test strips.
    I can say that you should read Pool School and go through the shock process outlined there. The extra FC will kill all the algae and remove the affect of the algaecide. However, it is more inefficient trying to go through that process without the proper test kit.
    Mar 2012
    Amarillo, Texas
    341
    I would highly, highly suggest you buy the recommended testing kit. The pool store gives you inaccurate information and the test strips are worthless. It's worth the 65 bucks to keep your pool clean and sanitized and with little ones their safety is your top priority.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    May 2011
    Clearwater, FL.
    446
    Hi Scrapnmama and welcome to TFP!
    Almost 3 years ago I bought a new 15' X "48 Intex pool.
    Pool store always had me adding something all the time and I was really never happy with the water...seemed they just wanted me keep coming in and having my water tested. Free testing! (just to buy this, then next week , Oh, you need this...)
    2nd season, I just wanted to try to understand pool water chemistry, did a Google search and landed here last year in April.
    I did some reading here and I realized it was really all about not using the pool store and testing your own water and adjusting what the pool water needed. Well that sounded good to me...after dealing with the pool store the year before. I did get the TF-100 test kit and because I wanted to learn faster to test a lot (slow learner) I added the XL option.
    I followed these instructions here:
    what-we-need-to-know-to-answer-your-questions-t10341.html
    Posted my test results with my new kit and got a overwhelming amount of replies and help.
    When that happened, I knew I was in the right place!
    It will be hard at first, but will become very elementary in a short time.
    Get your test kit, start a post and we can help you on to a Trouble Free Pool.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    May 2011
    Clearwater, FL.
    446
    Oh yeah, I forgot... go here to read about the test kits:
    pool-school/pool_test_kit_comparison
    C
    TF-100 test kit
    Jul 2012
    5
    Wow!!!! Amazing fast helpful service... I'm so glad I stumbled across this forum. I will track down a Taylor kit tomorrow a.m. and post results here!
    Scrapnmama
    5,000 gallon
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Quote Originally Posted by Scrapnmama
    If you're buying local, you want a K-2006. DO NOT let them sell you a K-2005, they're not the same, no matter what the salesman says. It has to say FAS-DPD, not just DPD. If you shop at Leslies, this is their part number http://www.lesliespool.com/Home/Pool-Ch ... 81329.html
    http://tftestkits.net sells the TF100 with all the same reagents, just in more useful sizes.
