Results 1 to 10 of 10
Thread: Batteries for Speedstir
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Ok, this is really embarrassing to ask but... how the heck do I put batteries into my new speedstir device? I can only imagine I need to find a really small screwdriver and remove the one screw. Right?
    Yippee
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Batteries for Speedstir
    Yep.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    JohnT beat me but...Yep...and AAs IIRC
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    A #00 Phillips. Don't try the end of one of your wife's good kitchen knifes, either. You'll snap it off. Oops, I'm probably too late with this. If there's any rust showing, give up.
    A drill with a 1/8 bit will open it, too. Takes the head right off. Friction fit seems to keep the lid on just fine, mine's been holding for about a year.
    Jan 2010
    Randleman,NC
    620
    Also replace with lithium battery's..They will last longer&it really give the magnet a real work-out.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jan 2012
    7,364
    Quote Originally Posted by Richard320
    LOL, I *am* the wife. Skippy is my husband. Thanks for the heads up on the size of Phillips. I think Skippy has eye glass screwdrivers that might work.
    Yippee
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    Just got my TF-100 and opened the SpeedStir purchased previously. Sure glad I found this old thread Skippy.
    I kinda thought it would be that one screw. After all these years they haven't changed it.
    No mention in the instructions either.
    I can't find my small eyeglass screwdriver so will have to wait to Speed Stir.
    All I can test now anyway is tap water until my pool is plastered and filled.
    My 2016 Build 14'x19'x35' IG Gunite 15K Gal. Roman, 4'-5' deep, 6 returns, 3 sheers
    4 deck jets, 2 Pentair XF22005 Pumps, Clean&Clear 200 Cartridge Filter, Brick Coping
    2 Pentair 5g 12v LED Pool Lights, 1 Pentair 12v Globrite LED in step area, 2 Bubblers
    Inline Chlorinator - SWG later, WetEdge Mediterranean Pebble, Intermatic MultiWave
    43'x33' Screened Paver Deck&15'x30' Lanai, Doheny Discovery (S200) Robot, TF-100
    Lrooth's Avatar
    May 2012
    Pittsburgh
    101
    Me, too! Found this old thread. Batteries died this morning. Can't get the screw out. Was going to hardware store to buy a special screw driver, but this thread indicates that if its rusted, don't bother. Of course, mine's rusted.
    Hmmm..... It test swimming pool water. Water, chemicals, metal.... Probability of rust is pretty high. Could they use a stainless Steel regular screw?
    I'll try to drill out the screw or Another $30 ..... I can't live without it!
    Lucy
    40K gal, painted plaster, Pentair FNS Plus 48, Hayward Super Pump 2 HP, Hayward H-Series-250, 50 years old, 3-month swimming season
    IrwinK's Avatar
    Apr 2016
    Orlando, FL
    338
    I was able to get the screw out using my smallest philips screwdriver. Did not need the eyeglass screwdriver. Screw appears to be chrome or stainless steel now. We'll see how it holds up.
    The cover won't stay on without the screw so I put it back but didn't tighten it very much just in case.
    38,403
    I can not remember, but I thought the screw was just into the plastic ... if so, not sure why rust would prevent you being to remove it. Maybe I do not remember correctly
