Results 1 to 11 of 11
Thread: DVD / CD PROBLEM
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    DVD / CD PROBLEM
    I cannot get my dvd player or cd player to work on my computer. They have power. When I insert a disc nothing happens. Any suggestions would be most helpful.
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: DVD / CD PROBLEM
    What kind of PC, MS windows operating system? Is that 2 different drives? If you look at the file system can you see the drives listed there and click on them? Could be a few different things.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    PC is a HP, windows XP 62 bit. Yes it is 2 differant drives.
    Aug 2011
    Gainesville, fl
    53
    Are they listed in my computer?
    12"x33" Summer Escapes AG Ring Quick set 1590 Gallons (Gift for my son by Grand-parents)
    Intex Krystal Clear Model 633 2500 GPH "B" Cartridge
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Yes, they are both listed and it says they are working properly.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    32 bit?
    So, if you put something in the drives and you browse to them via My Computer then you see data files? If so then it sounds like the Autorun feature is not turned on. You may also have broken player software. DVD's need a specific player but music CD's can use Mediaplayer. You could stick a music CD in and open Mediaplayer manually to see if it plays the music, if it does then I suspect the Autorun feature is off.
    Check out this site and look at solution 1 & 2 under the XP section.
    Mike
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    62 bit!! There's your problem!!
    Ok, silly question here. Have you tried rebooting? Quite often solves a lot of problems (reloads drivers for example). And just in case it's a codec problem download and install VLC media player. Lots of places to get it. Softpedia.com has it.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I meant 32 bit. Can't see any files. Message is "insert disc" or "no disc inserted" How do I check for autorun?
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Sorry, I meant to post the Autorun thing but didn't. http://www.annoyances.org/exec/show/article03-018/
    If you do not see any files then you probably have a hardware issue. Drive is bad or drive controller has issues. You can check to see that the drivers are still setup but seeing the drives actually show up then I doubt that's the problem. If you go to where you see the drive in My Computer and right click on it you can then go to properties and see if it's recognizing it. If still nothing then you'd have to try another drive or your drive in another computer.
    Mike
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Your input can't be opened:
    VLC is unable to open the MRL 'dvd:///E:/'. Check the log for details.
    This is the error I get using VLC.
    Jul 2011
    844
    Have you got a regular data CD you can pop in to each drive. If it can't read that, I'd try what MikeInNH suggests. Try your drive in another computer or another drive in your computer. That will narrow down the possibilities a lot.
    Bestway SWG
