Thread: Aerator question - raising ph and lowering temp
    Apr 2009
    South Texas
    177
    Is there a difference in the type aerator you need for raising PH vs one for lowering water temperature? I've searched and found aerators that spray from above the water and those that spray from under the water. I ask because I need to do both. With solar cover on the pool is up to 95 degrees, sometimes hotter. And I also need to lower TA from 190 to add borates (hoping it will help with bees and more sparkle never hurts). So can I accomplish both at once or do I need different aerators? BTW I, too, have sparklypoolitis! BBB and those of you providing the advice/wisdom on this site are AWESOME!!! Thank you.
    Just bought a new house in the country, no pool yet. :(
    Hot tub..500 gals..bromine
    TF100 test kit and speedstir
    38,475
    Re: Aerator question - raising ph and lowering temp
    The cooling comes from evaporation and the TA drops from exposure to the air as well. I think that anything that is spraying the water up into the air will do both. The finer the water droplets, the more affect you will see.
    Some people have used air compressors to blow air down into the water. I have to think that this would not lower the temperature as much, but would still affect the TA.
