Results 1 to 19 of 19
Thread: Pull or not to pull wedding cake steps in the winter
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    Good day
    First post here
    Very nice site lost of great info
    Lets get to it
    I just installed a 24 round with a Grand Entrance Step
    This thing is a monster, Do I need to pull it out fro the winter?
    Thanks
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    22,539
    Re: Pull or not t pull wedding cake steps in the winter
    If you have hard freezes you should pull them out. If not then it's optional. I don't pull ours out but it never freezes here enough to matter.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Didn't pull ours out last winter. Probably should have though as I just recently found that the hand rail had green algae growing inside of it which I wasn't aware of until I was vacuuming with a mask on and saw a green gunk puff out of a hole when I moved to vacuum underneath. It'd be best to remove the hand rail of course it would have to be removed to put a cover over the pool, didn't cover last winter so the steps, rail and all stayed in.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Our pool freezes pretty solid so always pull the steps. I think ice would make a mess of the plastic steps. It's a pain but better than buying new ones.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by MikeInNH
    thats what I was afraid of
    Well i didnt put sand in the steps yet I think i will rig some gallon jugs with sand that I can remove so that pulling it out may be easier
    --- Greg----
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I zip tied a plastic Rubbermaid type bucket to the bottom horizontal piece on mine. I then put a few decent size rocks (nerf football size) in another bucket that drops in the first one. I drilled holes in both so I can remove the bucket with the rocks in it relatively easily when it's time to take the steps out. Putting the steps in is easy, lean it over the pool a bit then slide the bucket of rocks in and slide it over the side. I need a helper to hold it but no biggie and no issues with bags of sand ripping open.
    Mike
    Makdaddy's Avatar
    Jul 2012
    119
    I Like that Bucket idea more then the sand jugs
    you wouldn't have any pics would ya?
    are the Buckets the round type?
    And both pails are plastic I assume
    Thanks
    Greg
    --- Greg----
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I don't have any actual pictures but I doctored a screen shot for you, pretty sure the screen shot shows the size I have. The buckets are actually Sterilite I think and are clear, it's good to be able to see in them. They stack really well and drilling holes makes the water flow in and out of them easily. I do not use the covers. In the picture the black lines would be the steps and horizontal brace at the bottom. The red circles are zip ties attaching the lower bucket to the brace. The bucket with the rocks just drops into the other one.
    Mike
    Makdaddy's Avatar
    Jul 2012
    119
    Thanks Mike
    That looks like it will save me some time
    Ill let you know how it works out
    But dont quit your day job to become an artist J/K
    Greg
    --- Greg----
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Lol, 2 minutes with the win 7 snipping tool.
    Mike
    Makdaddy's Avatar
    Jul 2012
    119
    Re: Pull or not to pull wedding cake steps in the winter
    Hey Mike
    I looked at the steps tonight
    I have the Grand entrance set
    Are you using that one or another type?
    I dont have any easy way to get the tub installed
    The back is enclosed
    --- Greg----
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    No clue what brand mine are but the back is open on mine. Looking at some pictures of what you mention it looks like that's gonna be tougher. Is it the one in the link below? I wonder if you could fill some PVC pipes with sand and cap the ends. Drill a hole in one of the ends to feed rope through before the cap is glued. Then if the top step comes off easy like the PDF appears to show you could just hang it from the sides under the step. Or you could zip tie larger PVC that the weighted PVC fits into under that same step or on the outer sides. PVC wouldn't be too intrusive or ugly on the external sides.
    http://www.aqua-pool-warehouse.com/IG/O ... uction.pdf
    Mike
    Makdaddy's Avatar
    Jul 2012
    119
    yea thats the monster
    Im looking at 2.5 gallon pales with plastic handles filled with sand then hang them on the inside ledge of the steps on stainless S hooks
    --- Greg----
    Mar 2013
    Atlanta
    6
    I used 2 cinder blocks inside mine and they did a pretty good job. I think a third one would do the trick better.
    We recently had our liner replaced and were able to get some installed under the liner, much cleaner install than those honkers!
    Dawg
    Dawgdays
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Another great idea I saw here was to get some PVC tube (2 - 3 inches or so) and 2 end caps for each pipe. Glue one end cap and then fill with rocks or sand and then glue the other cap, do several of these.
    Mar 2013
    Atlanta
    6
    Quote Originally Posted by cramar
    I saw that post too but I believe they are more expensive than the cinder block option...
    Dawgdays
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Perhaps, but one slip with a cinder block and bye bye liner.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yea that cinder block would leave a mark!!!!
    Jeff
    Smykowski's Avatar
    Sep 2011
    3,065
    I ended up doing this, and filled the tubes with concrete. I bought 2 10' lengths plus the caps, so I probably spent $20 tops.
    Cleanest safest way I could think of to add the weight to the steps. If I drop one, no big deal. Plus, they'll pretty much last forever.
