Results 1 to 8 of 8
Thread: Remote pool thermometer
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Anyone recommend any specific remote thermometer for pool temps? I'd like to know what the temp is from the comfort of my recliner. I had a $20 jobbie that I used for my woodstove room, and the manual said the probe was good for spas and pools, but alas the probe went haywire and constantly read 138 degrees, which is a little too warm for me.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I'm bumping because I'd like to have something too. I've considered some of the weather stations with multiple temp sensors, but I never know if they would tolerate constant immersion.
    I found one possibility. A number of other vendors used to carry this but now list it as out of stock.
    Aug 2007
    Austin, TX
    343
    Here are some:
    http://www.brookstone.com/sl/product/67 ... ystem.html
    http://www.nu-temp.com/601.htm
    (I have this one, the temp probe was DOA. They are sending me a new temp probe. This one has a 100' range but it almost needs a direct line of sight. I had to mount the transmitter at the end of a PVC pool which I painted to blend it in. If I had it to do over, I would go with the Brookstone model.)
    At the far end...
    http://www.hammacher.com/publish/74131. ... at=1511450
    Keep an eye out for range. 100' seems like a long distance until you put a wall or two between the transmitter and receiver.... That is why I am thinking about the original unit from Brookstone.
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    I have one from La Crosse... works great. It came with the standard outdoor sensor and then I bought the probe sensor separately. I got it a couple years ago, so not sure if they are still around but I can probably find the paperwork if you want model numbers.
    You can also play some fun pranks when people come over and ask you what the probe is for.
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    thanks folks. I like to be able to monitor temps, strange habit/hobby? I have therms all over the house in the winter to try to get the "perfect" airflow for heat so I can spend the least amount of money as possible.
    ktdave's Avatar
    Katy, TX
    888
    Quote Originally Posted by Molson
    We might be related, I have no less than 10 therms in and around my house
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    I really want one of the complete wireless weather stations. But its just not in the budget right now.
