Thread: In the decision phase...need help .
    Hello
    I'm trying to decide on a PB and I've gotten together with 4 of them. Each one using pretty much very different equipment. Now I feel more confused than ever. This is from the body of the last quote:
    Plumbing & Equipment
    2 in. and 2.5 in. PVC schedule 40 plumbing
    Dual 2 in. PVC main drains
    Independent suction lines
    Zodiac/Jandy zero maintenance valves
    5 return lines set 12 inches below waterline
    Zodiac/Jandy 1.5 HP full-rated pump. ( I will upgrade to variable speed)
    Zodiac/Jandy 460 sq. ft. cartridge filter
    Auto fill line
    400,000 BTU Jandy heaters with electronic ignition and dual thermostats
    Now under "Miscellaneous" there is listed a floating chlorinator. It actually took me a while to even find it. He never really pointed it out during our meeting. I was so overwhelmed with questions it completely got a way from me. Any advice or suggestions as an alternative would be greatly appreciated.
    Thanks again.
    Inground shotcrete, deco & glass tile, 30' x 15', 6 ft depth, 401 sq. ft., Sta-Rite VS3050 pump, 400 Sta-Rite Mod Media Filter, Sta-Rite Max-E-Therm Heater, Intellichlor Salt Chlorinator, PV3 Infloor cleaner, IntelliBrite Led Spa & Pool lights. Quartz - Blue Cayman finish.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,414
    Re: In the decision phase...need help .
    How large is the pool supposed to be and what kind of features will it have?
    Love TFP? Become a
    TFP Supporter!
    Pool
    The original design was for a 27 x 15 (319 sq ft) We've increased it to 30 x 17.
    ASTM grade 40 steel reinforcing schedule
    Shallow end steps and wet deck with umbrella sleeve
    White plaster interior
    marine light
    6" std waterline tile
    18" raised tiled beam
    Spa
    6ft Area:36 sq ft
    Raised 18 inches
    Split bench
    6 jets with air injectors run by common pump and blower
    marine light
    6ft spillway to pool
    Plumbing as stated in topic post
    Cleaning system
    Suction type cleaner included with dedicated suction line (does not specify which cleaner)
    Miscellaneous
    Plans, permits and engineering
    legal disposal of all debris
    rehang portion of fence and gate to pool coed
    window/door alarms per code
    complete start up with necessary chemicals, operating instructions and normal maintenance equipment to include: telescopic pole, wall brush, leaf net and floating chlorinator.
    Deck
    560 sq foot of spraydeck with cantilever forming over type II base
    Deck drain as required
    Spraydeck existing patio
    OK so now here are the options...
    Pebble Fina interior
    Polaris/Caretaker infloor system
    Zodiac/Jandy PDA 4 hand held remote
    Green Package: UPgrad to LED color changing light and variable speed pump (2 lights in pool, 1 in spa)
    Nature2 Fusion with 35,000 gallon mineral cartridge
    Perfect Pool 24 hour ozone system.
    Any guidance is greatly appreciated.
    Thanks again.
    (....do the LED lights...) I am a complete newbie myself, but I think you'd enjoy the lighting.)
    Can't help on the rest really - I think having the variable speed pump will save you money in electrical costs... but you'll hear from one of the many experts here. Good luck! I'll be watching your progress!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
