Results 1 to 9 of 9
Thread: Draining a Ultra Frame pool Quick. without a shotgun.
    I had to drain my pool. I was trying to use well water, being cheep, but OMG I had a black pool less than 24 hrs after filling it. I used the filter pump to drain all the water and I got it down to less than 2 inches but it could have been better. First I just took the skimmer basket loose from the bracket and let it hang in the pool and I hooked the return line from the filter to a long piece of 1" PVC using one of the adapters so I could pump the water out to the street. I pumped the water down to well below the skimmer fitting in the pool and then removed the entire fitting from the side of the pool. I found that if you take the blue fitting that the strainer hose plugs into you can take the vacuum hose and stuff it inside the blue fitting and it's a pretty tight fit. I then put the vacuum hose through the hole where the skimmer fitting was and started a siphon into the pump laying the pool valve on the ground next to the pump so it was not the high point. This way it did not suck a lot of air into the pump. I then hooked the vacuum hose to the vacuum attachment in the pool and cleaned all the gunk and orange dirt off the bottom of the pool with the vacuum until I had the pool mostly clean. I then left the vacuum attachment in a low spot on and it didn't stop sucking water until there was just over an inch of water. Now I could have done better if I had thought about draining the pool when I was trying to make the bottom smooth. If I ever take the entire pool up again I will make a 2" deep depression about 2' around to create a low spot to drain all the water from the pool. I am pretty sure that it will not effect the pool sides as long as I make the sides of the depression gradual.
    bottom line. well water bad. And put a Drain well depression in your pool.
    May 2012
    Boyd, Texas
    93
    Re: Draining a Ultra Frame pool Quick. without a shotgun.
    I hear lots of horror stories about people filling their pool with well water, guess I lucked out with mine. Filled with well water and it was perfectly clear, slightly elevated TA but overall clear sparkly water.
    Sorry to hear about yours though.
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    You did try using a metal sequestrant first, didn't you?
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I have never heard of totally black water from a well, do you have any pics?
    Was the water black as it was going into the pool?
    Or did the black show up after chlorination?
    I did mine the same way.
    Well water. Dark as it could be.
    then we threw shock in it.
    And filtered it for like 4 days. Vacumming it as well
    Crystal clear now and I love it
    20 x 48 Intex Ultra Frame
    Sand filter with SWG attached.
    Deck added on (05/18/2013)
    Thinking about adding more deck
    Pool steps added in - (got rid of that crappy ladder that came with Intex pool) 05/18/2013.
    "A little bit of paradise in our yard"
    The water was orange going into the pool and was black after I ran the salt water system for 7 hours. I would have tried to stick with it but I could already see the stains on the liner and was worried I would end up with a clear water pool just to see orange stains on the liner. I am hoping that once I get the water right that shocking it will bleach the stains out.
    Chris
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Orange water can usually be filtered, though I am not sure the intex filters (I am assuming intex?) could do it. What are you going to use for water the next time you fill? Anytime you can get metal free water in a pool, that is good thing!
    Yes it is an Intex pool. I live in Norfolk va so I have city water that is perfect and I have used it for years in my 18 ft blue blob intex pool but they no longer let us report that we filled a pool and not charge sewer charge so I was trying to fill my new 12x24x52 intex pool on the cheep. I filled today and was swimming this afternoon. Just not looking forward to the water bill. I was at the plumbing supply store talking about filling the pool with well water and he warned me about using well water and then he said I rent water meters. I said why and he said you swap out the meter then fill your pool and change it back. I was shocked but when I get the bill I might wish I had.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Quote Originally Posted by zaxs
    wow... ummm... guess one could just buy one and never pay for water again since it's just that simple
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
