Thread: Pentair 011511 impeller removal
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    I have a Pentair 011511 that looks like this.
    The pump is making very bad noises like a bearing is going. I am trying to take it apart to see what the problem is. I removed the motor and diffuser from the pump housing. How do you remove the impeller, does it take a special puller? I took the screw out of the center and gave the mounting plate a few tugs but didn't want to get too aggressive with it.
    19000 gallon inground fiberglass pool
    Hayward Pro Series Sand filter S244T 62 gal/min
    Whisper Flow WFE-2 / 011511 1/2 hspr pump
    Aqua Rite AQR Pro SWG, T15 cell for 25000 gal
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Pentair 011511 impeller removal
    On my Hayward Super II pump, I had to remove the end cap off the motor (opposite end of pump). There was a nut that's part of the shaft that the impeller is screwed on to. Held that nut with a wrench, turned the impeller with hand. Your model appears to have an impeller lock screw on the impeller itself as well. Here's a manual that might help http://www.pentairpool.com/pdfs/WhisperFlo%20OM.pdf.
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    That is awesome. Thank you very much for the link to the manual. I tried searching for about an hour, even at the pentair site and all I could find was sale or feedback sites.
    Sep 2011
    Clarksville, Arkansas
    2
    This helped me.
    The pictures are very good.
    Ron L
    pentair-whisperflow-seal-replacement-how-to-w-photos-t10763.html
    Inground pool, concrete 40x15x8, Painted, Built on an old rock quarry, Whisper Flow 2 1/2 hp pump - 60-70 gpm flow, 600 lb sand filter
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    Both posts were super helpful so thanks a ton. I fixed it all back up for under $20 today and it is like brand new.
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    Thanks to all the help I got the seal changed but I noticed that the seal plate was cracked around the thread inserts. I put it back together gently but it didn't last very long at all before the pump started leaking. I pulled it apart and sure enough it pulled all 4 threaded inserts out of the case then bound on the shaft cracking the ceramic seal. I read the thread below about similar plate problems.
    strange-seal-plate-damage-pentair-whisperflo-pump-t4517.html
    The part number is Pentair 350201.
    Anyways, after looking for a replacement part one of my local pool guys couldn't find that number so he looked it up and came up with a different replacement part number 074564. I googled it and came up with an ebay ad and it shows both part numbers for the same part.
    The 350201 is $169-189 locally.
    The 074564 is $69.95 locally.
    If it is the same part what is with the price difference? I am going to assume the 074564 doesn't come with the seal and gasket but that amounts to $15 in parts no $100. Anybody?
    http://compare.ebay.com/like/1606524289 ... si=y&cbt=y
    http://www.yourpoolhq.com/pentair-35020 ... e-kit.html
    Update: I picked up my 074564 seal plate today and it is the plain seal plate with no seal or gasket. Not sure why it is so much cheaper than the other part number though.
