Thread: Checking to see if i am going in the right direction
    Aug 2011
    Clarks Summit,Pa.
    37
    I will start with my test #
    FC 2
    CC 1
    TC 3
    PH 7.5
    TA 100
    CYA 80
    TEMP 86
    CH 300
    SWG is only 9 months old so i run at level1, 35% was ok for a while but we had a lot of rain and
    my salt went down to 2700 so i just added 40 lbs. the chlorine is low so i also turned it up to 45%, i run
    the pump 8 hours per day ,just checking to see if i am going in the right direction
    12,000 gal. 14x28 Inground vinyl liner (2004), 1 HP. Jacuzzi magnum pump,
    Raypak heater, Jacuzzi laser sand filter,Autopilot DIG-220 SWG, 35/22 cell,
    TF-100 test kit,K-1766 saltwater test kit, speedstir
    Re: Checking to see if i am going in the right direction
    Yes, you are generally doing alright. However the CC level of 1 is a little worrisome. It is probably just a side effect of the FC level being a little low, but it could be a sign of something worse. I suggest you add a little extra chlorine manually, to bring it up to 5 or 6, and if CC isn't down to 0.5 or lower by tomorrow you will need to shock the pool.
    With CYA at 80, you want to keep the FC level at 4 or higher at all times. You may need to turn up the percentage more to active that, or you might have a low level algae problem. If things aren't going better by tomorrow it would be a good idea to do an overnight FC loss test.
    Aug 2011
    Clarks Summit,Pa.
    37
    Thank You
    Last week it was at 6 so i hope that i turned it down to much ,i went from 50% to 35%
    and the rain water did not help,it had been staying steady all year ,my first problem with it ,seems like it was my fault but
    i will recheck in the morning,live and learn,i will go back to 50% also
