Thread: Test results - 2 questions
    el_steak's Avatar
    Aug 2007
    Ottawa, Canada
    110
    In the last week, I worked on getting my pool ready to start up the SWG. Stocked up on the BBB goods and worked my way slowly to what seems like a good balance.
    Here are my current test results:
    FC: 3
    CC: 0
    PH: 7.4
    TA: 80
    CA: 120
    CYA: 80
    SALT: 3200
    Except for the CA, those numbers are all in line with the SWG manufacturer and with the info I found in the stickies.
    1- Should I do anything about the low CA level? the manufacturer recommends 200-400. I have a vinyl pool and I think I read somewhere on this site that the CA level was not an issue for vinyl pools.
    2- I have quite a lot of cal-hypo (HTH) left from my pre-TFP days. I know tri-chlor and di-chlor will raise the CYA level and lower the PH. I don't think cal-hypo raises the CYA level, but does it have other adverse effects? (Since its already paid for, I'd rather use it all up before I start running the SWG)
    14X24 ig vinyl pool 3ft-4 1/2ft deep - 7000 gal
    Aqua Genie skimmer and return - no main drain, 1 hp hayward pump, 27" Hayward filter with Zeobrite,
    Aqua Logic P4 controller + SWG, 2 lights
    192 square feet of solar panels controlled by P4, 5KW electric heater (just in case...)
    Guest
    The cal hypo wont affect CYA but it will raise the calcium. You ar right that calcium is not needed in a vinyl pool and your level right now is fine but raising it a bit by using the fcal hypo won't hurt.
