Thread: First Results. Not so good. ):
    Jun 2012
    Los Banos, Ca
    7
    FC: 0.6 ppm
    CC: 0
    PH: 7.8
    TA: 250
    Calcium: 665. (um..?)
    CYA: Big fat 0
    I just tested right now.
    Intex Metal Frame Pool 12x30
    Intex 2800 GPH Sand Filter
    Taylor k-2006
    Los Banos, Ca
    38,475
    Re: First Results. Not so good. ):
    Welcome
    Yup, you are right, not so good ....
    What does the water look like?
    Jun 2012
    Los Banos, Ca
    7
    Hello!
    The water is currently a light green tint and it's a tad cloudy.
    Taylor k-2006
    Los Banos, Ca
    38,475
    Have you read Pool School? Do you have a plan of attack?
    The high CH can be managed by controlling the pH and TA.
    But, first you have to clear your water.
    Raise your CYA up to 30-40ppm, verify/adjust your pH to about 7.2, and then start the Shock Process described in Pool School.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Adritard
    Jbliz has got you covered! This pool school article may also be helpful: http://www.troublefreepool.com/pool-...efeating_algae
