Results 1 to 17 of 17
Thread: Pressure gauge
    Jul 2012
    Toulon, Illinois
    43
    Pressure gauge
    My pressure gauge is running around 20 after replacing the standpipe, manifold and laterals. Before the repair, the pressure gauge was between 10 and 15. Two days ago I found that my manifold was in about 3 pieces hence the replacement. My question is, should my pressure gauge be reading that high? After I backwash and rinse it stays at about 12 for a few minutes and then creeps back up to around 20.
    21 foot by 4 foot AGP, Jacuzzi Laser 192 sand filter, Hayward 1 HP pump, approx. 9100 gallons, install 7/15-7/17/2012
    22,553
    Re: Pressure gauge
    Sounds like it's clearing some stuff out of the pool that was bypassing it before. I'd say that's a good thing.
    Jul 2012
    Toulon, Illinois
    43
    Re: Pressure gauge
    Excellent Bama! I will keep backwashing then, what should my pressure be at normally? Before I realized that the manifold was in pieces, the filter was pumping sand into the pool faster than I could vac it out.
    22,553
    Re: Pressure gauge
    I'd say 12 psi.
    Jul 2012
    Toulon, Illinois
    43
    Re: Pressure gauge
    When it gets to 20 psi which is every 30 minutes or so, the return loses a lot of pressure. Once I backwash and rinse it seems to restore return pressure. Water that is coming out of waste while backwashing doesn't look dirty. There is a little sand in sight glass but water never looks horribly dirty.
    Jul 2012
    Toulon, Illinois
    43
    Re: Pressure gauge
    Would not having the proper amount of sand in the filter cause high pressure?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pressure gauge
    Your pressure is fine right after backwashing, so I would guess you have the right amount. Do you suspect (other than from your pressure) that you have too much? How much did you put in?
    When your pressure goes up and you backwash, what does the water look like as it is coming out of the backwash port?
    Jul 2012
    Toulon, Illinois
    43
    Re: Pressure gauge
    I was concerned that maybe I didnt have enough sand. I put back in what was in there that we took out to repair. The previous owner had just changed sand. When I backwash the water looks clean.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pressure gauge
    Sorry, i missed that you had already stated the backwash water is clear.
    Wow, so your pressure goes up from 12 to 20 psi within minutes and your backwash water is clear?
    Something does not sound right with the filter or valve.
    Where was the sand level (approximately) in the filter once you had put it back in?
    Any bag left over that indicates what the previous owner put in there?
    Jul 2012
    Toulon, Illinois
    43
    Re: Pressure gauge
    No left over bags, over a foot of sand is in the filter. Would a bad O ring or air leakage at the top of the filter cause the pressure to be crazy? I noticed last night that it would get to bout 20 psi and the skimmer would loose suction, if i put my hand over skimmer hose and would "plunge" it with my palm suction would come back. Pressure would drop down to around 15 or 16 psi.
    22,553
    Re: Pressure gauge
    If the pump is losing suction the pressure should go down not up. When the pressure goes up how is the flow from the return?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pressure gauge
    Does your gauge go to 0 when the pump is off?
    Jul 2012
    Toulon, Illinois
    43
    Re: Pressure gauge
    Yes
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Pressure gauge
    Is there any possibility that you got sand in the standpipe or laterals when you were putting the sand back in?
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Jul 2012
    Toulon, Illinois
    43
    Re: Pressure gauge
    I dont think so. We had duct tape over standpipe when adding sand.
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Pressure gauge
    One other possibility, the previous owner changed the sand with play sand instead of filter sand. Filter sand is much coarser than play sand. Play sand would quickly clog with only small amounts of dirt, causing a quick increase in pressure.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pressure gauge
    Yes, since you do not know what sand they put in there, it might be the wrong stuff. Only way to fix that is to replace with new pool filter sand. I am not sure showing us a picture of some of the sand would help...maybe...not sure I would be able to tell without seeing the good stuff side by side.
