Thread: 1st pool, have questions
    Jul 2012
    Colleyville, TX
    20
    Hey all,
    I'm in the process of purchasing a new house that already has an in-ground pool in place. This will be my first pool, so I'm pretty excited about it. We do, of course, have one issue that I need your help on:
    The current owner was upfront about the pool light not working, so we made it a condition in the offer that we wanted the light fixed. They agreed and had 2 pool companies come look at the light to estimate the damage. Both pool companies are reporting the same issue. There must have been damage to the conduit carrying the pool light line and they are unable to trace it to repair it or to tie in a new line. There is no indication on who actually built the pool (older pool), as the current owners aren't the ones that built the pool and there is no documentation available to give us this info. Both companies are telling us the line is damaged and unfix-able without having the pool plans to see where the light wire comes out of the pool, otherwise we'd have to dig up the entire back yard to search for the line. The interesting part is that the spa light works fine and the issue is just related to the pool light. Are they not the same line?
    Given that this is my first experience with anything like this, I'm looking to you guys for advice. Any thoughts/recommendations?? I don't think I can pass on a house based on a pool light, as we are otherwise very happy with the house. But, I'd like to figure out if there is a resolution here.
    Your help is appreciated!!
    +/- 17,000 gallon IG gunite pool & spa; Mini pebble; Oklahoma flagstone; Water feature; Pentair catridge filter; Pentair MiniMax 75 heater (replacing in the future, too small); Dolphin DX4 Robotic cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: 1st pool, have questions
    I've been in my house for 2 1/2 years and we still haven't fixed the already broken pool light. Don't consider it a deal breaker. I am guessing we would use it if we had it, but we don't miss it.
    Jul 2012
    Colleyville, TX
    20
    I'm not letting it kill the deal. We like to sit out on our current patio at night time and wind down, so I'd just like to have the option of sitting out there with the water sparkling. I think we'll call an electrician once we get in the house to see if they can figure anything out, but just wondering if anyone else has any suggestions.
    Mar 2012
    Fayetteville, NC
    10
    I would dig where the cement ends directly behind the light. Most times it comes straight back. Is there a junction box sticking out of the ground somewhere?
    14x28 13,200 gal IG Vinyl
    Pentair SD60 60gpm
    Pentair SuperFlo 3/4hp
    2 Aqua Genie Skimmers
    TF100
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    It's not incredibly difficult to find, you just have to have the right equipment. They can put a tone generator on the line that will actually let them find the path of the conduit, and locate the break even, if it severed a line. Someone just didn't want to do it. You need to contact a utility locator service, they do this every day, marking lines underground!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
