Results 1 to 9 of 9
Thread: First water problem - Little cloudy
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    My fault but I always let me chlorine bottom out. It has always been crystal clear so i never gave it a thought. I check every other day and always have to get it back up to 5ppm from 0. Well, today I learned my lesson.
    I left my pump off. I usually turn it on about lunch time but today I forgot. Mental note to get a timer. I walked out after work ready for a dip only to find a light cloudiness to the water. Test results show FC 0 as usual. I usually only add enough to get to 5PPM which is 382oz.
    Today I added 450oz and will check daily until I see how much it needs daily to maintain the 5ppm rather than every other day. The pump is running and the water already has a clean blue look but the water is still cloudy. Hoping I didn't let it go too long.
    My readings:
    FC 0
    CC 0
    pH 7.6
    CYA 40
    TA 120
    I am mulling over the idea of running the CYA up to 50. Thoughts? I know CYA protects chlorine and since my pool is in 100% sunlight it stands to reason it would benefit from the extra. Thoughts?
    I am going to take a dip in a few minutes. It has been running for about an hour now so I figure its safe. I am going to run my first OCLT tonight to see how it comes out.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Aug 2010
    Dallas, TX
    4,052
    Re: First water problem - Little cloudy
    I know it's been hot as hades here in the D/FW area, but I don't know about going to 50 on your CYA. If you have a problem, it'll be that much harder to rectify.
    I'm concerned about you having cloudy water. Before I had my SWG I had a couple of times it hit 0 for a day, but I never had an outbreak. I was lucky every time.
    Your TA is kind of high, any idea where your CH is? High TA and CH can lead to cloudy water.
    OCLT is a good plan!
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I won't mess with the CYA if its a bad idea. I definitely don't want that. My CH has been holding steady at 130 since day 1. My TA is climbing very slowly. 100 to 110 to 120 in a few weeks. Only fresh water has been added. I do have alot of sun screen wearers in the family. Not sure if that has any bearing. I added a scum ball to the skimmer too.
    Aug 2010
    Dallas, TX
    4,052
    Well, I don't think CH is your clouding problem. OCLT results pending...
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Nighttime OCLT reading 5ppm
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Do I keep my pump running overnight?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Indeed. It'll help clear any dead cloudies (algae perhaps).
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Well, I left it off and went to get my reading just now. 3.5ppm (tested twice to make sure) and water is crystal clear again. Weird. Yesterday even in the pool and under water with goggles on I could see the bottom of the deep end but it was cloudy and had a discolored tinge to it and it kinda had a smell to it, gone now of course. Now, crystal clear and blue. I wish I had gotten a picture yesterday of the before.
    On a lighter note, my scumball is working great.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Glock
    Sunscreen and excessively high bather load can result in water losing a bit of clarity even when chlorine levels are adequate. I experience that effect after every pool party. Extra filtering time takes care of it.
