Thread: Gre ABG pool, can I dish the botem out?
    Hello,
    I live in Portugal and want to put an ABG pool inground but here I can only get pools from Gre,
    It is the oval 23ftx12ft with 4ft hight but I want more swimming hight and my question is can I get more hight by dishing the bottom out with the original liner of the pool?
    Here you can see a video of the pool being set up:http://www.youtube.com/watch?v=ZOq8u_K_Zms
    The liner is an 40mil liner but dont know if this will stretch to 5ft or 5.5ft hight.
    Buried oval above ground pool, 12x24, 7000gal
    Using the BBB method
    Sand filter 45kg, Pump 1000gph.
    Living in Portugal, Europe.
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    Re: Gre ABG pool, can I dish the botem out?
    Our oval pool has straps under the pool going from one side to the other to help brace it since it is an oval shape. Liners typically are very difficult to reuse. You would have to do a quick job of take down and set up as the liner dries out and shrinks. It is hard to line up the skimmer and return where they need to be as well.
    As far as getting a deeper end it would depend upon the straps (if any under your pool) and how you plan on setting it up. Original liner won't work I wouldn't think, but I am a newbie so others will chime in.
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
    I watched the video and I don't think this type of oval can have a deep end. The main reason is the straps that run under the pool to provide structural support for the buttresses which keep the sides where they need to be. If you can find a manufacturer that supports a deep end you will need an expandable liner which will mold itself to the contour of the pool/deepend as the water rises.
    Good luck
    24 Ft Sharkline Matrix , ~15,200 Gallons
    Pentair SD60 w/ 2 speed 1.5 HP Dynamo pump
    Taylor K-2006 --- BBB
    It is a pool with straps but I have seen here that you can cut them in half and dig them in and attach a cement block to them like in this post: pool-under-construction-t34670.html
    The pool is new and must be set up for the first time so the liner is new to without any cuttings for skimmer and return valve.
