Thread: New at this...Electricity
    I live in Mississippi & just bought a 24x56 AGP...the installer didnt give me any info on what I should or shouldnt do regard ing electricity to my pump! The first time I heard anything about grounding was this past weekend, since then Ive been afraid to swim in my pool! I have a hayward pump. I contacted the pool supplier & he said it wasnt necessary to have it grounded but everything I have read says that it does....NOW Im also hearing about bonding? I am so confused!!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: New at this...Electricity
    Welcome to TFP!
    Many above ground pumps are double insulated and don't require bonding. If yours requires bonding there will be a lug on top to put a wire in.
    If the panels in your pool are resin, they may not require bonding either. Tell us about your pool and equipment.
    I am in the same shape as Tonya. Here are the specs: 33' ABG with 25000 gal, swimpro voyager sand filter with a 2hp 2 speed voyager sp1520 pump. I can't find the gpm pumping. Thanks.
    Thanks 4 any help...I have a Pacific AGP it has steel ledge, steel uprights & resin caps, the walls are galvenized steel...a Hayward sand filter system w/1.5 hp pump...I am very confused...the pool supplier said it was not required but Im not so sure
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Pool suppliers leave a lot of that info out because it turns customers off. Telling them they have to hire and electrician and do extra bonding work makes the cost go up in customers mind so they conveniently leave that info out. We ran into the same problem, but they threw in a free bonding plate for the skimmer when we politely told him that that $50 plate should have been included with the pool since we bought a full package.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Electrical specs vary region to region. My town hands out the spec they want adhered to when someone gets a pool permit. In my case, it's a weatherproof twist lock plug for the pump 10 feet away from the pool and has to get there using stranded wire in leak-proof plastic piping that is 18 inches deep. Everything also needed to be bonded with a ground loop around the pool. Loads of fun.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
