Thread: ready to buy, need some advice
    I've decided to purchase a Tahitian 33' round and have been told to get
    1. .5 HP Hayward "Super" pump, mfg. model #SP2600X5
    2. 22" Hayward "Pro" sand filter, mfg. model #SP220T
    3. Hayward 1.5" "Vari-flo" multiport valve, mfg. model "SP071113
    4. Cord set 25' long, mfg. model "SPX1550WA
    Can someone tell me if these are right and would they be adequate for the pool I have chosen. Opinions and advice would be greatly appreciated. Thanks a bunch, Donna
    --Guest Too
    IG liner, Sand Filter, Polaris 360, 18x36 oval, 29,000 gallons
    Welcome to TFP!
    That looks like a reasonable combination to me.
    You might want to think about getting a larger filter. You current filter is fine. A larger filter would reduce the frequency of backwashing and slightly improve the efficiency of the entire system. It will be fine either way, but the improvement in connivence of the larger filter and water saved by reduced backwashing might be worth it in the long run.
    Now I can buy!
    Thank you so much. This will be my first AGP. Want to do it right. I am so thankful to have found this website. I am going to purchase the TF100 test kit. Will be coming back again and again, I've got a lot to learn. Once again, thank you so much. You guys are great!!!
    --Guest Too
    Butterfly's Avatar
    South Carolina
    10,045
    Hi dosu and welcome to TFP!
    Congrats on the new pool!
    Having the TF test kit before the water goes in the pool is putting you way ahead of the game!
    Please keep us updated with your progress.
    You're done SLAMing when:
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
