Results 1 to 8 of 8
Thread: Easiest Way to Enlarge Grill Cut Out Opening
    Has anyone had to enlarge the grill cut out in an outdoor kitchen? When we bought our house it had a 27 inch DCS grill that just died beyond repair and most reasonable replacements require 2-4 inches of additional width. Any suggestions on how to approach or ideas of cost for a carpenter to come in and increase the width. Thanks in advance.
    Re: Easiest Way to Enlarge Grill Cut Out Opening
    what's your counter top made of?
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    heat siphon heat pump
    it's made of ceramic tile and the tile runs from countertop into cut out. There is hardiboard underneath for liner.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    To cut already installed tile, you can use a grinder with a diamond tile blade.
    Depending of course on the structure of the cabinetry underneath (the wood). Enlarging any hole largely matters upon if there's support structure under the part you want to cut out.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    I'm partial to angle grinders. Just get the right kind of disk for it and be careful. Maybe clamp down a piece of wood so you can't slip off course. http://www.harborfreight.com/4-inch-ang ... 91222.html
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Quote Originally Posted by MikeInNH
    I have used a circular saw with a tile blade and also like the angle grinder. A friend of mine who does a lot of tile likes the grinder also.
    17,000 gal inground
    vinyl
    swg
    3hp 8 returns
    Thanks for all the responses. Gonna plan it out and give it a shot.
    May 2011
    Orange County, CA
    696
    What's under the hardiboard? I would imagine this is built up of either steel studs, or rot-resistant wood of some type (e.g. pressure treated) as the framing. In either case, the cutout for the BBQ head likely was built up with cross members holding up the corners and possibly holding up the bottom of the cutout. To expand the cutout, it may be necessary to redo the frame surrounding the cutout to ensure that it will properly support the BBQ head and the corners of the tiled surface.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
