Thread: how do these results look?
    May 2012
    Tulsa, OK
    14
    Here are results from today. Just wondering if I need to adjust anything. water is clear.
    FC 3
    pH 7.8
    TA 150
    CH 350
    CYA 50
    I have been doing the BBB method all summer with only one hiccup. I am so thankful I found this sight.
    Thanks for all the help here.
    25,000 gal, sand, IG, gunite with attached spa and waterfall
    Aug 2010
    Dallas, TX
    4,052
    Re: how do these results look?
    Your FC is a little low, I would target 8 at your addition, never drop below 4, with a CYA of 50. As long as your pH isn't drifting, I wouldn't worry about TA of 150, but you can lower it if it is a problem.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How does your water look?
    RobbieH has you covered!
    I would lower your ph down to 7.2, this will also lower your TA a little. When it comes back up to 7.8, lower it to 7.2 again (as before your TA will lower a little more).
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    Quote Originally Posted by linen
    I would agree with lowering TA and getting chlorine up a little. With you waterfall, it should be easy to aerate pH back up when needed.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
