Thread: Water leak around return jet
    My in ground vinyl pool has lost water to just below the return jets. Can they be a source for a leak? And what steps can I do to repair.
    22,553
    Re: Water leak around return jet
    It's most likely a plumbing leak. If you plug the jet off does it still leak down to that point?
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Thanks for the quick reply. I"m trying to eliminate causes of leaks around the return jet before getting into a plumbing problem which is way beyond my expertise. I'll try your suggestion first just to be sure. Is there a gasket which could have gone bad?
    22,553
    It's rare for a fitting gasket to fail while in service. By plugging the return you'll know if it's a gasket or the plumbing.
