Thread: Is there such a thing as a bug light for a pool?
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    My daughter and son spend half their swimming time at night rescuing the bugs that fly in. Are there any bug lights for pools? I suspect people don't want to light a pool with that yellow light but just wondering.
    In a way I suspect my clear water from BBB is adding to the problem...
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Is there such a thing as a bug light for a pool?
    We don't use our light while swimming for that very reason. We have tiki torches that we use for light to avoid drawing bugs.
    That's been the only bright side to the drought. No bugs!
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Our pool has never had a light. There is a street light just outside our wall that casts a soft even light over our backyard. With our "BBB" pool being so clear, I can see the bottom with just that amount of light.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Oct 2010
    Pensacola, FL
    67
    Instead of using our pool light, we have an LED color changing spotlight mounted under our sunroom eaves and projecting out onto the pool. It also has a remote. Think I got in on ebay.
    http://www.alibaba.com/product-gs/52167 ... light.html
    Bill Moyer
    CWO4 USN (Ret)
    Pensacola, FL
    10k gallon 12x24 in ground pool built 2008, vinyl, Pentair Intellichlor IC40, Pentair Intelliflo v/s pump, Hayward sand filter. Using the BBB method.
    Jul 2012
    NW FL
    91
    Security light here that kicks on and off... Hi to neighbors in Pensacola .
    I'm assuming you are wanting to replace reg bulbs with yellow ones? I like the idea of the tiki torches... Citronella to boot... Some of the color changing LEDs look cool! Let us know what you find out / decide
    Darn autocorrect!
    ~6500 gal 18' x 52" easy set agp, 7th year
    Intex 2650 sand filter, chlorine
    TF100 Test Kit
    Becoming a TFP lifetime supporter and purchasing the TF100 is absolutely the best money I have ever spent! :-D
    Feb 2008
    Denton, TX
    5,061
    I would be curious to know if amber LED lights were less "buggy" like the old yellow light bulbs we used to see all the time.
