Thread: Foam Cove, What order
    I am sure this has been discussed before however I had a hard time locating it. I have peel and stick foam cove, Do I install 2" of sand first then foam cove, or foam cove first? I don't have the foam cove in my possession yet so I am not clear on the order. Thanks Foamer
    Asahi (used) 27' 52", 18,000 gal, Cartridge filter, Above Ground, 1 1/2hp pump, New install 8-1-12
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    Re: Foam Cove, What order
    Most instructions from the Cove manufacturers say to install the Cove before spreading your sand.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    22,543
    I just went and read all of Gladon's cove instructions and they all say to have the pool floor finished and compacted before installing the cove. I read that as having the sand in place before setting the cove.
    The best thing to do is read the particular mfg's instructions for the cove you get.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    This info can be very hard to find, I had a hard time anyways, never really did find it from my manufacturer.
    My cove was notched at the base to account for the bottom rail, my logic was: if I put sand first than what is the point of the notch? It's just empty air because the pool base will be even with that bottom rail.
    I wanted the notch to be reinforced by the rail, so I put the cove down and then the sand - being careful where the 2 meet.
    If there is no notch in the cove I'd put on top of sand.
    I'm not saying what's right from wrong, but 2 summers in and my cove is fine.
    22,543
    Mine has the notch too but in my case I didn't use sand. My pool sits right on compacted earth with a Gorilla pad so the notch was needed to sit over the bottom rail.
