Fiberglass - we have a 6" piece pealing & 10" thin crack
cody21
324
Lafayette, Ca / USA
Fiberglass
So, this whole Fiberglass pool thing is very new to us - vs. Plaster. Not sure how long ago the new fiberglass coating was done - the previous owner is kind of clueless.
We noticed a piece of the fiberglass has slightly cracked and about 4mm pulled outward (on side wall towards shallow end) - what I mean by that is that I can actually put my fingernail under the crack since some has pulled away from underlinment - although I haven't pulled on it (for obvious reasons). There is also a 10" or so hairline crack that is evident in the shallow end.
So I guess my main questions are:
- What is underneath the Fiberglass when they apply or spray it on? Is it sprayed directly onto Concrete or Plaster?
- Does a crack like these compromise anything (leaks, etc). Or are these fairly normal in IG Fiberglass pools?
- How expensive is it to re-do Fiberglass when the time "comes" ? I know it's subjective - just a ball park figure given 31,000 capacity. $2,000 ? $20,000 ?
- Anything else I need to be aware of for Fiberglass?
Thanks all.
