Results 1 to 14 of 14
Thread: Compupool CPSC 48 Died 15 months. FIXED 8/14
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    My CPSC 48 is 15 months old. This morning did my test (all good) and turned on my my pump and the CPSC 48 didn't fire up. Reset the CB on the bottom, all lights came on then released button and all went out.
    Called customer service, got Tim on the line. He stated he believes the LCD module is bad. Will send e-mail me paperwork to swap it out.
    Added a gallon of bleach.
    We'll keep you posted.
    Aug 2010
    Dallas, TX
    4,052
    Re: Compupool CPSC 48 Died 15 months.
    I never called about mine. I turned down the % and I quit having problems. I think mine needs to be recalibrated and I ended up with 5800 PPM salt. So, my theory is that when it was turned up to 90%, it was overheating. It was getting unbelievably hot on the back of the unit. At 70% it's not shutting off anymore. I'm watching for my salt level to go down due to splash out and backflushing, then going to call them and recalibrate. THEN I'm going to keep an eye on it to see if it ever shuts itself off again.
    I've heard those problems regarding the LCD panels, but I didn't feel that was my problem.
    When the LCD panel goes bad, does that cause the unit to quit running?
    Apr 2011
    Murrieta, CA
    2,360
    Got the paperwork, sent it back. Awaiting the part.
    Robbie I run at 80% and haven't had a problem. Are you on 115V or 230V? I'm at 115V and know what you mean about kicking off. (TMPSTLTEST (Temp Salt Test) I think is what it runs to cool down). It happens sometimes at 100%)
    Aug 2010
    Dallas, TX
    4,052
    230v.
    When mine goes off, it goes ALL THE WAY off. Everything is off. No LCD display, no lights, power button does nothing.
    Apr 2011
    Murrieta, CA
    2,360
    Spoke with Tim this morning parts are packaged up and being sent.
    I'm manually adding 182oz of Chlorox 6% a day I do miss the chlorine generator.
    Apr 2011
    Murrieta, CA
    2,360
    Just an update:
    Spoke with Tim this AM, there sending me a whole control panel set up for 115V. It's on back order, but may be sent by the 10th. It will come FedEX and I should get tracking info from FedEX once it ships.
    Aug 2010
    Dallas, TX
    4,052
    Mine had been running fine on 80% for weeks. Of course I have a big party and it turns off on me. I need to call. It does come back on, and I still think it's a heat issue.
    Apr 2011
    Murrieta, CA
    2,360
    8/10 update. Still on back order, they are sending out a new control box but are awaiting arrival of cable that goes to the cell. Should be in on Tuesday, then replacement will be shipped out on Wednesday. NUTS.
    Apr 2011
    Murrieta, CA
    2,360
    Great news. The part is on the truck to be delivered today 8/14. I'm expecting a whole new control box. We'll see and I'll post an update.
    Jul 2011
    phoenix
    133
    outside of the unit being dead, how have you liked it? functions features, or features you wish it had? I was debating getting this one this coming fall
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    Apr 2011
    Murrieta, CA
    2,360
    Part came in today. A new control box, 30 minutes later and it's working fine. I'm happy. Took about 3 weeks from reporting till it got fixed with replacement part. Got the return shipping label with the delivery. They've fixed the problem. I'm satisfied.
    Iciee: I like the unit overall. It produces chlorine. No lugging jugs and makes the daily maintenance much easier. I'm not sure about the bells and whistles. It looks like they've changed the software that states "SALT OK" instead of giving a number. I don't have a problem with that. As long as it produces chlorine. I'd recommend the unit. Even with the glitches I've experienced. Customer support has been fine.
    WestSidePool's Avatar
    Cincinnati, OH
    424
    I'm still surprised you guys are running it at outputs of 80% with such an oversized unit. Are you only running it for a few hours s day? I keep mine at 30-40% for 8 hours. Keeps the levels fine.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Apr 2011
    Murrieta, CA
    2,360
    My pump runs about 10 hours a day. Full sun. Gets debris from trees daily.
    Re: Compupool CPSC 48 Died 15 months. FIXED 8/14
    I also have the Compupool cpsc Series. I called them and they said my LCD board could be bad. Reason- I have the signal indicator % bar like a cell phone signal staying in the same bar level on display; even if I turn up to 100%. The low and or high salt indicators are not coming on and I know I had low salt two weeks back. Otherwise, it powers on and off and goes through the cycle. I have just noticed no chlorine in the pool test at the normal 30% rate and have bumped way up. I really do not know if the board is bad or not. I do know that the cell will make Chlorine at higher %; if I really know what that is.
    21, 000 gal BLue fiber glass with Salt System 16x 33
    Aiken, SC 29803
    great water balance
    Hayward Pump
