Thread: Deep End Base Question
    Jun 2012
    NW CT
    77
    Well..............the project has begun. I am 1 week into my 21X43 AGP with hopper liner. I just poured the concrete footers yesterday for the deep end side uprights. So here is my question for planning ahead. I have a dig sheet for the beaded hopper liner, but am wondering if this is the dimension before or after my base material? This is a hopper liner and not an expandable liner. I'm thinking this needs to be right or the hopper won't fit and i will have wrinkles. So should I just dig according to my dig sheet and then put in my base material? If so how think do you guys make your base, 1-2 inches? My plan for my base material is what they call around here is pond silt. It looks like pool sand mixed with a fine clay. it holds together and packs nicely but is finner than sugar.
    thanks
    43x21x54" Sharkline/Wilbar Above Ground with hopper, 26,000 Gal
    Sta-rite 22 in sand filter with Zeosand removed reg pool sand installed, Sta-rite 1.5 hp pump, Poolsmart Climber Robot, TF-100 Test kit, poolskim, hard plumbing with second return added for poolskim, fafco solar heater, Luiquidator
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Deep End Base Question
    Best bet is contact the manufacturer and get the proper direction.
