Thread: Fresh after pool refill. TF-100 test results
    Jul 2012
    Clinton, IL
    6
    Ok guys, after my failure to battle the deep green swamp and with my CYA being over 100 I took most people's advice and drained and refilled. Here are my fresh pool test values:
    FC= 1.0
    PH= 7.5
    CC= 0
    CH= 70
    TA= 500
    CYA= 0
    TC= 1.0
    I am on well water so that is probably why the TA is high maybe. I did have it tested once for iron and it was not high. I want to start the BBB process. What do I work on correcting first guys?
    Thanks- Jebarr
    16' x 48 " 5061 Gallon Above Ground Pool with Intex SF15110 Sand Pump 1650 GPH
    Aug 2010
    Dallas, TX
    4,052
    Re: Fresh after pool refill. TF-100 test results
    Get your CYA up. Target 30 for your first addition. Bring FC up to match your CYA level. Use poolcalculator.com for assistance.
    May 2012
    Boyd, Texas
    93
    I would also make sure you have some muriatic acid or some PH down because its probably going to start climbing with a TA that high.
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
    Aug 2010
    Dallas, TX
    4,052
    Good catch, I totally missed that TA number. I'd put some real focus on getting that down.
    pool-school/lowering%20total%20alkalinity
    Hey Superman, I grew up near Briar. Small world.
    May 2012
    Boyd, Texas
    93
    Yep I started with a TA of 300 and a PH of 7.2 and I'm adding around 30oz of acid every other day.
    Lol, definitely a small world Robbie.
