Thread: How much borax is TOO much?
    Jul 2012
    Pittsville, MD
    8
    We've been using the BBB method since starting up our pool on July 1st. It's 3740 gallons and to date, we've used roughly 95oz (almost 6lbs) of borax to adjust the pH. The fill water was from the town supply and it's pH was very low. Our TA is currently around 90-100 and the pH has been holding steady around 7.2. We'd like to be around 7.5, but are concerned about adding any more borax to the water. We've read that unlike chlorine, the borax will remain in the water and becomes toxic at higher concentrations. Our question is, how much is too much? Have we already used too much for a pool this size?
    As for the rest of the levels, our CYA is 30-40 and we've been holding FC around 5-7. Also using 4-6oz weekly of Stain prevention and remover to keep the water clear. The BBB method combined with the apparent metal(s) in the town water likes to turn the pool a transparent green color.
    Summer Escapes 14' x 42" Metal Frame AG | 3740 Gallons | Cartridge Filter / Skimmer
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: How much borax is TOO much?
    Those that borate the pool, (including me) run at a level of about 50 ppm. That would be about 14 pounds of Twenty Mule Team Borax, given you pool volume. You would have to get much, much higher than that before getting into any toxicity problems.
    chiefwej
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Many of us actually add borates to 50ppm for these reasons:
    1) more stable pH
    2) Algaestatic properties
    3) reduced chlorine usage
    4) silkier feeling water--less skin and eye irritation
    5) clearer, 'sparkling' water
    from so-you-want-to-add-borates-to-your-pool-why-and-how-t4921.html
    According to the pool calculator, 96oz of 20/20 Mule Team will raise your borates by 22ppm. So, you're well away from any danger of being borated by using borax to increase pH :~}
    I've got to say, the borates have served us well, into the 3rd season now. This year borates were low at opening, somewhere between 15 and 20ppm. The water lost it's sparkle and didn't get it back till borates were added back to 50+ppm. There's a significant difference in the glintiness and sparkle, after becoming used to it for a couple years it was apparent when it wasn't quite enough.
    Borates in the 50ppm to 80ppm range are considered acceptable, but most of us aim for 50 and keep it there.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Feb 2008
    Denton, TX
    5,061
    If you are wary of using too much borax, you can consider aeration to raise your pH.
    May 2011
    Clearwater, FL.
    446
    Hi SteveMac,
    I would raise the TA up to 120 and see if that gets the pH up a little higher and holds there. Here is from Pool School:
    You can raise TA with baking soda. It is often best to make large TA adjustments in a couple of steps, testing the water after each one, as adding baking soda will also affect the pH and you don't want the pH going out of range. If you need to lower your TA level, see How To Lower Total Alkalinity.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
