Thread: FAS/DPD test...am I doing something wrong?
    kdubya815's Avatar
    May 2009
    Columbia, TN
    123
    I let my FC get too low a few days, so I am shocking I went to test my FC level, and when I put in the scoop of the powder, the water turned a pale pink. However, when I started adding the drops, the water started getting a stronger pink instead of clearing! I did use the OTO test to see what that showed and it turned very orange, which I understand means the CL is high. I have never had this happen and I have used the TF-100 kit for 3 seasons! What am I doing wrong? Or does that indicate a major problem? Thanks in advance!
    18x36 Grecian style vinyl 23,000 gal inground pool, Hayward Pro Series S220T sand filter, Hayward Super Pump 1 hp.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: FAS/DPD test...am I doing something wrong?
    It indicates super high FC. Use 2 scoops of powder and see what you get.
