Results 1 to 10 of 10
Thread: IS THIS ALGAE? OH NO......
    Jun 2012
    Howard City, MI
    54
    Just got over my algae issue and the whole 4-5 day shock process. Kids were in pool tonight and I noticed several dark clumps on bottom of pool. I scooped several of them out and they are the same "asterisk/star-shaped" matter that I noticed in the pool before when the orangish film appeared on the bottom edges (shady areas).
    What is it and what do I do? I took a few pics (the best I could) to try to show the matter.
    My levels this afternoon at 3 p.m. were as follows:
    FC = 6.5
    CC = .5
    pH = 7.4
    TA = 140
    Temp = 80 degrees
    Per Pool Calc and above numbers, I added the following:
    1) 6.7 oz of 6% bleach
    2) 16 oz Borax
    PLEEEEAAAASE HELP! Tomorrow is my birthday and I was so hoping to relax and forget my worries floating in the pool.
    Above-Ground Pro Series 18'x48" Metal Frame - Approx 6,450 gallons
    Skimmer Filter System (cartridge): SFS1000 w/ F1500C Pump: 120watts/2.0amps/1500g.p.h
    Purchased & Installed: 6/7/12 (week of)
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: IS THIS ALGAE? OH NO......
    That looks like some kind of small animal poo to me.
    What do you use to test your water? You didn't post a CYA number, which leads me to believe you don't have a proper kit. Almost all of us "helpers" here use the TF-100 or Taylor K-2006 test kit.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Jun 2012
    Howard City, MI
    54
    Quote Originally Posted by Vette
    I put the cover on every night so don't think its that. Yes I have the Taylor K-2006 but when I tested the pool this afternoon there wasn't any matter in it and I don't test the CYA every day. Should I test that and post as well?
    Vette's Avatar
    Jul 2012
    Ohio
    404
    CYA should never be tested everyday, if you have any recent results from testing it, that will suffice.
    If its algae and mold, then I'll bow out and let someone else who specializes in that help you out. Algae isn't my specialty.
    Jun 2012
    Howard City, MI
    54
    I tested CYA this past Friday (7/20) and it was 46.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    If you press and smear the black things, do they smear and show green? Algae will smear green.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Jun 2012
    Howard City, MI
    54
    I tested my levels this a.m. and they are as follows:
    FC = 6 (stayed the same as last night)
    CC = .5 (very faint pink)
    pH = 7.8
    Had some of the dark clumps of "matter" in skimmer basket this morning and still some on pool floor. I did squish one of them and it was dark brown. What in the world is this stuff and how do I get rid of it? I am ready to pull the plug on this pool and send my kids to the nasty lake.
    Please Help!!!
    Jul 2010
    England, UK
    156
    Looks like poop to me too. I'm always surprised by how much poop and insects can get into a covered pool, but they do.
    90k litres, outdoor in ground pool, concrete, painted (I hate paint)
    Sta-Rite 5P2R 1.5 Hp pump, undersized sand filter (needs upgrading).
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, looks like critter poop. Just dip/vac/clean it out. I suggest you lower the pH to about 7.4ish. Then add a couple extra FC.
    Now, get your fav libation and enjoy your pool. Happy Birthday
    You're done SLAMing when:
    Jun 2012
    Howard City, MI
    54
    Oh brother!!!! I have seen A LOT of frogs in back yard lately. Yuck, it could be frog poop or eggs? Nasty Nasty Nasty! That just makes my skin crawl. Is there a way to keep frogs (or whatever it is using my pool as a toilet) out?
    Will keeping my FC higher work? Is it safe to keep a steady FC of 8 or 9 constantly?
    Quote Originally Posted by Butterfly
    Thanks so much Butterfly.........I surely will enjoy....gonna be a good day (as long as I don't see any frogs OR poop)
