Thread: When is the best time to run the pool pump?
    Jul 2012
    South Carolina
    48
    I read somewhere on here about running the pool pump for about as many hours as gallons of water in my pool. The, try backing off some to find the most economical, yet beneficial length of time to run. Correct? I have ours running from early evening into early morning. Is there a best time? Also, my robot runs the entire time. Is that too much robot time for my plaster? We are still getting residual plaster in our bag when we are in balance and CH is 300.
    15 K gallons
    Gunnite
    Centurion Pump/Hayward Sand Filter
    Polaris 360 Robot
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: When is the best time to run the pool pump?
    Ideally you want to turn the pool over at least once, so that involves determining how many gallons per hour your system runs. Then you can decide on wether to run at night or during the day (costs versus pool temp desired).
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I'd say run when when the rates are cheapest if you're on a metered rate. Other wise here's some info from Pool School: pool-school/pump_run_time
    38,251
    There are pros / cons for running during the day vs. at night ... in the end it really does not make much difference. If your power at night is cheaper, that is a clear + for running at night.
    The length of time required to run your pump is really just long enough so the pool stays clean to your liking. See the link bobodaclown posted.
    I would think the robot run time should not affect the plaster.
