Thread: seems like I'm using a lot of bleach.
    Aug 2010
    Charleston, South Carolina
    77
    I just finished building our inground shotcrete pool. Plaster went in last Saturday and I've been testing and brushing non-stop. The SWG will be turned on in about 3 weeks but in the meantime, I've been adding 6% bleach from Lowes. But I'm going thru about 1 1/2 gallons a day. I'm in South Carolina so it's hot and the pool gets about 9 hours of every day. Maybe this is normal (I've never owned a pool before), but I was trying to keep the level around 4ppm but every morning when I check it, it's down to around .5 so I add another bottle. The water has been crystal clear since we filled it. Here are my test results from this morning
    FCL - .54
    TCL- .77
    PH - 7.5
    TA - 86
    CH - 260
    CYA - 48
    half Inground/half above ground, shotcrete pool, 19,000 gallons - KrystalKrete Krystal Blue quartz finish
    Pentair intelliflo variable speed pump - Pentair Easy Touch automation - Pentair T100 sand filter - Savi Melody LED lights - Mortex KoolDeck - Charleston, South Carolina
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: seems like I'm using a lot of bleach.
    That's about 4.5-5 ppm/day. I'd call that high.
    Your test results appear to be from the pool store. Something about accuracy to 2 decimal places... In which case, they're highly suspect. If your CYA isn't as high as you think it is, you'll lose a lot of FC to sunlight. If it's higher than you think it is, you haven't been maintaining enough FC, and you may have algae trying to get started, which will consume a lot of your FC.
    The real test if something's growing in the water is an overnight loss test. To do that properly, one needs the right test kit.
    Aug 2010
    77
    Richard, They're not pool store results. I've been testing with my colorQ Pro7. I know it has some limitations but I'm colorblind and I figured that would suffice. My CYA had been in the mid 30 range but I added some more stabelizer last night so maybe that will make a difference. Can I use the ColorQ to do an overnight loss test?
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by mlawrence17
    I don't know, I've never even seen one of those testers in person.
    Although colorblind shouldn't affect your ability to do the Taylor CYA test nor the FAS-DPD test. The CYA test is black-and-white, and the FC test goes from colored to clear. It shouldn't matter if you see pink or grey, just that you see it go clear as water.
