Results 1 to 9 of 9
Thread: Newbie that had green pit with frogs!
    May 2008
    North East Mississippi
    17
    Hi all, I found you last night when I was searching for answers. I stayed up until about 2 a.m. reading all the stickies. I have learned a lot...but still need some help.
    I took the cover off my pool 3 days ago and it was worse than I have ever seen. green and cloudy lots of leaves..that somehow got under the cover.. I've had the pool 4 years. It has gotten increasingly harder to maintain over the years with each season being harder than the one before.. here is a run down of my pool and problems...my pool is an 18 X 36 rectangular pool with 4 foot shallow end and I think an 8 foot deep end. I have been using chemicals from wal-mart- Aqua Chem. I used the test strips and that is all I have ever used. When I saw my green pit with 2 frogs swimming around in there..ekk.. I knew I had trouble... I poured chlorine.. the shock extra blue from aqua chem.. and a whole bottle of algaecide plus.. that I have now discovered I didn't really need to do and I looked at the bottle and it was not the one that began with poly.. it has copper in it. Ok.. first it turned a turquoise blue color and is lots better but still see algae on the bottom and it is very cloudy..can't see the bottom in deep end but can in shallow... I went to lowes today looking for all the BBB things I need to now run my pool... I'm learning... I don't have a test kit yet.. but ordering one tonight....I bought an Aqua chem kit that only test ph and chlorine.. it says my ph is low.. the color is lighter than the lowest reading on the kit... my chlorine is good ( I think).. the color is in the 3.0-6.5 color block.. so what to do now.. i've added ph increaser from aqua chem for two days.. and it's still low.. ( Used the test strips for that info and used the pool chemicals from aqua chem before I found you guys) What do I do now.... help!!!
    Thanks so much and this forum is great!!!
    Lanice in Mississippi..
    I took a photo of my pool..not sure if I got that in here correctly.. I did an attachment.. you may see cows in the background in a field behind my house... lol..
    Southern Girls Pool- In ground, 18X36 vinyl liner, approx 27K gallons with sand filter, booster pump for polaris, and Jandy gas heater in Mississippi
    Welcome to TFP!
    You need a good test kit. Without accurate numbers it is impossible to tell what is happening. I recommend the TF Test Kit, see the link in my signature, or the Taylor K-2006. While the test kit is on it's way stock up on bleach and read my writeup on cleaning up a green pool.
    May 2008
    17
    Thanks, I have ordered a test kit and I have stocked up on supplies. In the mean time I am just going to try to keep filtering, backwashing, and keep the chlorine up.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Lanice and welcome to TFP!
    Most of us use PhotoBucket.Com for their pix.
    You may be amazed how confident you feel armed with a good test kit.
    We have a lot of knowledgable people here to answer questions. Feel free to ask away!
    Keep us updated on your progress.
    You're done SLAMing when:
    May 2008
    17
    Thanks for the welcome! I am very fortunate to have found this forum. For the first time in 5 years I feel I have the knowledge to take care of my pool.... thanks to ya'll. Thanks for the info on photobucket, hopefully I will have the pics here.
    I will keep you up to date
    Butterfly's Avatar
    South Carolina
    10,045
    Wow! Beautiful pool!
    It really is a tranquil view. Wish I had it.
    Guess you know you had me looking for cows in the pasture!
    Thanks for the pix and feel free to post more
    May 2008
    17
    Thank you! It is such a relaxing place to be. I love it here. Hopefully I will be able to post a crystal clear pool in a short time. It looks so much better than it did. The green is going away, but still cloudy. I guess I need to be patient and wait on my test kit. Anyone know how long it will take to come in.
    saraiks's Avatar
    Jul 2007
    Fremont, CA
    74
    Don't worry.. green to clean takes just about a week if you are religious enough in your chlorine numbers... most of us have been there one time or the other and pulled through in about 7 days..
    16,000 G in ground Gunnite (plastered) with attached Spa, Gemini 3 NG Heater, Sta-rite cartridge filter, Aquabot Mark V, TF test kit
    30,432
    Hey, Lanice,
    Your order from Sunday shipped to you on Monday via DHL ground. You should've received an email Monday evening with a projected delivery date. My guess is your kit will be to you tomorrow or Thursday....not sure which.
    Did DHL not send you that tracking #?
    BTW, Thank you for your order.
