Thread: Power surge took out my pump?
    GregH's Avatar
    Aug 2009
    Dripping Springs, TX
    32
    After a series of lightning storms my Hayward TriStar pump no longer runs. It hums for awhile, and shuts off -- I was told it's a classic starter capacitor problem. Tried replacing the cap with a new one that had the exact same specs -- didn't fix it. Called a service company that did the same thing -- didn't fix the problem and they are telling me that I need to replace the whole pump motor. Seems like and expensive oversimplified fix. Any suggestions on my next step -- the pool is getting very green.
    20,0000 gal gunite IG pool, built May 2016. Jandy VS ePump, Jandy 60sfDE filter, AquaLink controller, PureLink salt water chlorinator, with Pentair Rainbow in-line chlorine feeder. Use a Taylor Total Poolcare DPD test kit. Heated by the Texas sun.
    GregH's Avatar
    Aug 2009
    32
    Re: Power surge took out my pump?
    I should have mentioned that I can reach in and turn the pump freely -- not jammed at all.
    Can't help on the pump, but I suggest taking FC up to shock level and using a Wall Whale brush to mix bleach into the pool. A good brushing with that Wall Whale a few times a day is called for.
    22,553
    Did you or they try cleaning the centrifugal switch contacts? If so then I suspect they're correct. It's time for a new motor.
    I'd use this opportunity to get a 2-speed motor if the one you have isn't.
    GregH's Avatar
    Aug 2009
    32
    I tried to figure out where the switch was located, but I was told that my 2hp 2-speed original pump was significantly oversized for my pool and filter size so I stopped working on that. I have a 1HP 2-speed replacement motor on order. Thinking a about replacing the circuit breaker with one that includes surge protection since lightning is so common here in Texas.
    38,450
    Since you are lowering the motor HP, you also will need to reduce the impeller size to match the motor ... this may also require additional parts (like the diffuser), but I am not sure on your pump setup.
