Results 1 to 9 of 9
Thread: SWG % Setting
    Jul 2011
    Philadelphia, PA
    22
    SWG % Setting
    Hello all.
    I was wondering what and how you determine your chlorinator setting. Currently it is running at 50%.
    Latest numbers: pH 7.4 TA 90 CH 320 CYA 80 TC 4
    Thanks.
    Todd
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: SWG % Setting
    You adjust percentage and pump run time to maintain sufficient chlorine for your pool.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Re: SWG % Setting
    Quote Originally Posted by JohnT
    For example, your chlorine appears to be in the target range. If you reduce the percentage, your chlorine will drop unless you increase run time on your pump. Conversely, if you increase percentage, you would typically reduce the runtime on the pump.
    The percentage is actually the duty cycle of the SWCG. 50% means it is generating chlorine 50% of the time the pump is running.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Dec 2009
    Virginia Beach, VA
    131
    Re: SWG % Setting
    Quote Originally Posted by elwood58
    Just to clarify, 4 isn't where he should be. Per the Chlorine/CYA chart in pool school his target FC is 6, so he needs to up his percentage or pump run time. Or am I missing something?
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
    Aug 2010
    Dallas, TX
    4,052
    Re: SWG % Setting
    For a pool on SWG, you only need to run 4ppm even at 80ppm CYA.
    38,521
    Re: SWG % Setting
    Well, 4ppm is the MINIMUM FC for a CYA of 80ppm in a SWG ... safer to run it up around 6ppm in case there is a sudden load increase.
    elwood58's Avatar
    May 2012
    654
    Re: SWG % Setting
    While I completely agree, he is totally in range with his FC, but on the low end of it. I think it is more important to understand how to make that number move, versus where you might choose to move it to. The OP did not share a lot of other details regarding his setting, sensitivity to chlorine levels etc.
    The general consensus here is usually to give yourself a buffer. Overnight rain and storms can really take a toll, and having a little extra keeps the green monster at bay.
    38,521
    Re: SWG % Setting
    @elwood58, totally agree.
    I was more trying to clarify the 2 posts before mine, so that tcmdo might have a better idea of what FC to be targeting when starting to adjust the SWG as you described.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: SWG % Setting
    You determine you're chlorine setting by testing your chlorine level over a period of days. If the chlorine level decreases you need to increase either the output setting or increasing the run time. If your chlorine level is increasing then you need to decrease the output setting or decrease the pump run time. Make small adjustments and test regularly.
