Results 1 to 10 of 10
Thread: Our Clean Pool
    Jul 2012
    NJ
    21
    Our Clean Pool
    A big thanks to the folks on this site that helped us get our pool balanced out. Here are a couple pics from today...
    30k gallon in-ground vinyl, sand filter
    Guest
    Re: Our Clean Pool
    A very nice looking pool and yard.........
    Re: Our Clean Pool
    Spectacular - the first one looks like you took it before you added water! Love the shape of your pool as well!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Our Clean Pool
    Can you post a full set of test results?
    Jan 2011
    Huntsville, AL
    67
    Re: Our Clean Pool
    I really like that pool!
    16 x 32 inground with Tara Liner, 1 skimmer, 3 returns,
    1HP Hayward Super Pump
    Hayward Sand Filter
    Polaris 280 w booster pump
    Hayward SWG & Aqua Plus
    k-2006 Test Kit
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Re: Our Clean Pool
    Awesome! When you gonna put water in that thing?!
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Our Clean Pool
    Great job Looks awesome!
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Our Clean Pool
    Spectacular! Very nice indeed. I want one!
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Re: Our Clean Pool
    very nice, looks relaxing
    18,000 gallon in ground, plaster - completed 6/29/12
    Jandy 340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    Jandy LXi 400 heater
    Jandy Aqualink PDA-PS4
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Our Clean Pool
    Looks fabulous
    You're done SLAMing when:
