Page 1 of 2 12 LastLast
Results 1 to 20 of 27
Thread: Need Help - Fighting Algae Continuously
    Dec 2009
    Virginia Beach, VA
    131
    Currently shocking my pool to clear up what looks like green algae. The water is clear but it's growing on the walls, especially around the light and ladder. I have brought the water up to shock levels and brushed the pool walls and floor. I am going to perform an OFCLT tonight. My SWG is currently turned off, at what point do I turn it back on? Tomorrow after I take my OFCLT readings? Do I need to remove the ladder and clean it and also pull out the light and clean in the nook behind it?
    Also, for those of you with SWGs, what % do you keep your SWG at? I had it at 60% but my FC is only 3 and my target is 5-6 per the chart. I guess I'll bump it up to 80 but does this seem high? My salt is fine (3620) and my CYA is roughly 85, the SWG is brand spanking new and my 1 hp pump is running 13 hours a day. Below are the readings before shocking. Any help is greatly appreciated...
    FC - 3
    CC - 0.5
    TC - 3.5
    Ph - 7.6
    TA - 90
    CH - 130
    CYA - 85
    Salt - 3620
    30,000 Gallon Inground, Vinyl Liner
    DE Filter & Pentair IC40 SWG
    Pentair Legend Platinum w/ PB4 Booster
    Pentair Kreepy Krawler Prowler Robot
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Need Help - Fighting Algae Continuously
    I wouldn't bother with the overnight test until at least there's no more green. And if you're not doing the test, there's no reason to turn off the SWG. Keep FC high - real high, given your CYA level - continuously and it will go a whole lot faster.
    Dec 2009
    Virginia Beach, VA
    131
    Just measured the FC and it looks like I overshot with the Chlorine a little. Was shooting for 30 and ended up at 38. That's not high enough that it will harm anything is it?
    Quote Originally Posted by Richard320
    There's no green. The only visible algae was on the walls and I brushed all that off after adding the Chlorine. The water is relatively clear now. So do I do the OFCLT tonight or not????
    Maybe my algae isn't green algae? The color certainly looks green to me but maybe I'm fighting mustard algae??? It only ever grows on the walls and floor, I never seem to have anything in the water. Looking for some advice here....
    Richard320's Avatar
    Jan 2010
    19,052
    Quote Originally Posted by jobondur
    Just measured the FC and it looks like I overshot with the Chlorine a little. Was shooting for 30 and ended up at 38. That's not high enough that it will harm anything is it?There's a chance you'll bleach out the vinyl liner. I kinda doubt it with your high CYA level, though
    There's no green. The only visible algae was on the walls and I brushed all that off after adding the Chlorine. The water is relatively clear now. So do I do the OFCLT tonight or not???? What is the CC level? If it's above .5, you're not done, so there's no reason to do the OFCLT.
    Maybe it is Mustard Algae - in which case the shock level for 85 CYA is 47!!
    Dec 2009
    Virginia Beach, VA
    131
    Re-tested chlorine level. FC is 39, CC is 0.5.
    So do I follow through with the OFCLT now?
    If not, what do you reccomend?
    Dec 2009
    Virginia Beach, VA
    131
    And how can I tell what type of algae it truly is?
    Your help is greatly appreciated.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I assume you've got a reading from tonight's dosing. And an alarm is set. Let's see what your tomorrow brings.
    And check/clean with tiny brushes any niches or step innards that could be harboring something green.
    Tell us what happens when you brush the algae spots. And consider more draining, 100ppm is seriously above a manageable level. I'm afraid if you're battling algae, that the CYA level is working against you. Regardless of what type it is.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Dec 2009
    Virginia Beach, VA
    131
    Quote Originally Posted by frogabog
    I'm confused, where did 100 come from? My CYA is 85 right now.
    I just ran the OFCLT test this morning. My FC is 35.5 and my CC is 0.5. So it looks like I lost roughly 2.5 ppm of FC over the night so I should keep the pool at shock levels for the day and do the OFCLT again tonight?
    I did the test at 6:15 am this morning, the sun was up but no direct sunlight on my pool. That's early enough right???
    I'll brush the ladder and crevices when I get home from work today. I assume I'll be ok getting in to clean the light niche?
    Dec 2009
    Virginia Beach, VA
    131
    Just set the SWG to 100%. Getting ready to leave for work. If there's anything I need to do prior to leaving, please tell me soon.
    Thanks.
    Feb 2008
    Denton, TX
    5,061
    Nope. Just keep shocking until your water is clear, your CC is 0.5 or less, and you lose no more than 1 ppm FC overnight.
    Dec 2009
    Virginia Beach, VA
    131
    Quote Originally Posted by 257WbyMag
    Thanks. You guys are awesome, love this site. I'll report the results when I get home tonight.
    Dec 2009
    Virginia Beach, VA
    131
    I know FC levels over 10 are higher than you should normally swim in. But I will need to get in the pool to clean out the light niche. Is an FC of 40 too high to do that? I assume I'll be in the water for roughly 5 minutes.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Sorry, I guess I confused your CYA level with someone else's. Or was just too tired...
    At a CYA level of 85, regular shock level is 22ppm. Generally it's safe to swim at or below shock level. So technically 40ppm would be stretching it a bit.
    However... take this example and use it as you will:
    My father had surgery once, a cadaver bone was inserted in his spine. He spent three years battling systemic MRSA, 15 surgeries, etc. till they removed the bone. It came back about a year and a half ago and his new physician gave some instructions for eliminating MRSA in the house which included taking a weekly bath with a cup of bleach added.
    So, let's say that a bathtub of water holds 50 gallons. Insert 1 cup 1 oz 4 tsp of bleach and the FC is now 100ppm. No CYA in bathtub water btw.
    You can take that as you will, but I take it as 100ppm FC ain't gonna do much harm to a person, and might even help some.
    Dec 2009
    Virginia Beach, VA
    131
    How did you get that shock level? When I go to the Chlorine/CYA Chart it lists a shock level of 30 for CYA of 80.
    I doubt my pool is still at 40, I just chose a number a little higher than I figured it would be for a fudge factor. I figured it would be alright on the skin but what about my hair? I'll likely wear goggles and go underwater and clean out the niche.
    That sounds like quite the ordeal your father went through, hope everything ended up turning out for the best.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    I got it from Pool Calculator. Which is less aggressive than the CYA/Chlorine chart in pool school. Either works, but when things get stubborn using the more aggressive CYA chart can help.
    Thanks for the notice, it was an ordeal for him, but so far so good sans the most recent reappearance. He's taken a lot of Vancomyacin. He's still alive at least. And he's now a BBB'er for his spa since I informed him that my kids would not be allowed to soak with him without sufficient chlorine. The mineral thingie he got sold on after burning out his heater with trichlor in a feeder (don't ask... darn ebay anyway!) is not able to kill MRSA and we've already had a few bouts here with the kids and some skin/nose MRSA. I hate to think he gave it to us (not me yet, thankfully) but I honestly don't know how else it got into our lives.
    Edit: The chlorine won't really do much to your hair, maybe dry it a bit only. Shampoo should take care of that. If you're thinking that chlorine turns hair green, it isn't so. It's actually copper (from algaecides) that creates the green hair of lore...
    Dec 2009
    Virginia Beach, VA
    131
    Left for work this morning with the SWG on 100% and the FC level at 35.5. Came home and measured around 4:30 and the FC was 26.5. I brushed the liner, cleaned the skimmer housings and returns real well, took off the ladder and cleaned it real well, and removed the light and cleaned it and the housing really well. When I removed the light there was a mound of algae sitting in there, looked mostly dead. Going to do the OFCLT again tonight and hope I pass this time. Wish me luck....
    Oh yeah, is 6:00 early enough to do the morning OFCLT reading? I don't have DIRECT sun on the pool at that time but the sun is definitely up...
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Good, you found and killed it!
    One caveat however... while running the SWG your chlorine loss tests are skewed. While shocking, it's best to turn the SWG off entirely, for two purposes:
    1 - Chlorine loss tests will be accurate
    2 - Saves your SWG cell
    By all means turn the SWG off for the OCLT if you think you can try it tonight but since you lost over 10ppm today with the SWG running, I'd say no, not ready.
    Dec 2009
    Virginia Beach, VA
    131
    I hear what you're saying but my top priority right now is to keep my FC up while nobody's home to maintain it manually. That's why I'm running the SWG during the day. I'll try the OFCLT tonight and report out.
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    OK, gotcha. Is 10ppm loss less or more than normal? Good luck with the OCLT. :~}
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    19,052
    During the shock process, it is normal. For a clean, balanced pool, it is extremely high.
