Results 1 to 15 of 15
Thread: ladder pad
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    ladder pad
    The pool is up! (Pics to come soon!). Water is being added as we speak! SO close!
    What pad do you have for under your ladder in the pool? How is it held down? Any help would be welcome. The ladder is a straight/simple set.
    THANKS!
    Kim
    Jan 2010
    Randleman,NC
    620
    Re: ladder pad
    Just a bathtub mat with the suction cup's on the bottom..Got it at Walmart.Just make sure you get the heavy duty one..Just cut to fit.But if you want all of it.It will work fine to..It will stay to the pool bottom.The one's the pool store's sell will not stay down..
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Re: ladder pad
    Hi Kim! I just searched this site for the same thing. Our pool is filling now. Our neighbor used a shoe pad (from Menards); the kind with holes in it. He said it works well. I like the bathtub mat idea! Did you get one yet? What did you go with? I know I can just buy one for $23 off Amazon but I figured there would be a cheaper product that works as well or better.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: ladder pad
    Somebody posted recently that they cut a section of a pool noodle and slit it and slid it over the end.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: ladder pad
    Just 2 days ago I cut a 6 or 8 inch length of noodle and tie-wrapped it around each leg of the ladder. Works great.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jan 2010
    Randleman,NC
    620
    Re: ladder pad
    The problem with pool noodles is they work great.But,they will start breaking apart after a short time because of the water&chemical's..They are not made to be under water 24/7..
    Jul 2011
    844
    Re: ladder pad
    I wondered about that. If I can get a month I'll be happy. Only gonna get 3 months for swimming here anyway!!
    Bestway SWG
    Jul 2012
    Tallahassee, FL
    30,559
    Re: ladder pad
    I did get a NICE bath mat from Big Lots for $7. It is clear with LOTS of sucky cups on the bottom. It is just the right size for my ladder. I have marked the date I bought it and will be keeping track of how long it lasts.
    http://www.biglots.com/search/product/4110
    Kim
    Jan 2010
    Randleman,NC
    620
    Re: ladder pad
    Quote Originally Posted by kimkats
    Kim
    I have found that the clear is better.It will turn milky white color..But,I have had mine for almost 3 yrs. on the sameone..I pull them out for the winter..
    Jul 2012
    Tallahassee, FL
    30,559
    Re: ladder pad
    Thanks that is nice to know. My husband (crazy) swims year round so I do not close the pool. At least he did when we had the last pool that I RUINED because I did not have a clue and the pool stores were NO help at all. They just sold me stuff.
    NOW I just laugh as I drive by the pool store! THANKS!
    Kim (money to help support the site will be on the way when I get over buying the pool)
    Re: ladder pad
    I've got three of these vinyl bathmats (with suction cups) under my steps (Lumi-O Festiva):
    http://www.homedepot.ca/product/vinyl-bath-mat/967654
    The (natural) rubber bathmats I used last season, from Walmart, literally dissolved after a month or two and seemed to encourage algae.
    So far, so good with the vinyl ones.
    "Inherited" Cornelius 18'x54" Round AGP (Steel walls), Hayward Pro Series 21" Sand Filter, ClubPro (Jacuzzi) 1HP single speed pump, Lumi-O Festiva steps, Toile-Soleil mesh leaf net/winter cover. That's about it.
    Jan 2010
    Randleman,NC
    620
    Re: ladder pad
    Quote Originally Posted by WorBry
    Ye, those will..Get the Heavy Duty one's they are around $8 ..Still using mine on the third season.No problem's.
    Re: ladder pad
    Do you have a link for the Heavy Duty one?
    I'm in Canada and Walmart here don't always carry the same range as the US.
    The vinyl ones I'm using seem quite durable but I'm always on the look out for something a bit larger. Even with three (30" x 16") I don't get complete coverage of the base of my steps. Rubbermaid do an Extra-Large mat (17" x 36") but again it's natural rubber.
    Edit: Would it be this one?
    http://www.walmart.com/ip/Heavy-Duty-Ul ... r/14710647
    As usual, Walmart Canada don't list it.
    Jan 2010
    Randleman,NC
    620
    Re: ladder pad
    Doesn't look the same.But, prob. just has good..I pick'd mine up in the store down the road.Like I said it's on the 3rd season.So they prob. don't sell the samething anymore.
    Re: ladder pad
    No problem. I'm OK with the mats I'm using for now.
