Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: another hard plumbed intex
    Apr 2012
    SW Ohio
    456
    i would like to start off by saying that this was my first pool ever and definatly the first time leveling the ground for a pool....whew!!!!!
    i started off by doing all the normal installation routine ie removing the sod and cutting down the high side to meet the low side, brung in 3 tons of masons sand leveled the whole area with a rotating laser level. set up the pool on concrete pavers got it all up and then i got the water balanced using the BBB method, all was going well for about 3 weeks and then my intex 1600 pump went out and had to argue with intex about a replacement pump under warranty. Well the day the pump went out we had a real bad storm go through the area and my pool looked like someone had literally took 5 gallon buckets of leaves and dirt and threw it in my pool, and i have no pump to vacuum my pool. i thought well there goes my water balance but i continued on with my normal routine and cleaning the leaves and dirt out of my pool manually until i got another pump.Luckily i kept my pool balanced with no ill effect from not having a pump for a day. so i went out and bought a hayward 1/2 hp 40 gpm pump and then started the mods which include a thru wall skimmer,2 returns a water fountain all with shut off valves and hard plumbed with 1 1/2 and 1 inch pvc. below are a few pics of my setup......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    Re: another hard plumbed intex
    and a few more
    i also made this towel rack for about 12 dollars
    i owe all this knowledge i have about pools to this forum because i was pool illiterate before i found this great webite......once again thanks TFP the greatest website on the web
    Apr 2012
    SW Ohio
    456
    and a little video also.....lol
    Vette's Avatar
    Jul 2012
    Ohio
    404
    I love it! Creative and that is gonna work great for aeration if you need to lower TA ever I am gonna hard plumb my pool sometime but I'm thinking of sticking with 1 return.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    poolgranny's Avatar
    May 2012
    Mid-Missouri
    120
    I like your fountain.
    Our system isn't hard plumbed, but would love to have someone do it so we could add a fountain similar to yours. I might take this project on next year prior to hooking everything up.
    Above Ground Pool 15' by 30' Older pool -- Make ? Model ? Cost - Free; Given to Us
    Gallons approximately 11,000 (if I figured correctly)
    New liner in 2007 when pool was moved and installed by son-in-law and family members
    Hayward Sand Filter 150 pounds of sand (purchased new in 2007)
    White River 2 horsepower pump (purchased new in 2012)
    Deck built in 2011
    Bioguard 1200V Multi-Test Kit with an additional Orthotolidine Chlorine Test Kit
    Apr 2012
    SW Ohio
    456
    if i think about it...i guess i have 3 returns.....lol
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Do you see any benefits from 2 returns? Our pool is bigger (21' x 54" deep) but we have good water flow with 1 return.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    You say you used 1 1/2" and 1" PVC. Do you have a tutorial???? I would like to hard plumb my intex and I am trying to figure out how you
    actually connected the PVC to the pool outlet and return. It looks like you have the grey intex hose nuts connecting the PVC to the outlet and return. I can't imagine how you did this. Will you please share?? Pretty please?? What size ball valves did you use?
    Am I correct in seeing that you use the skimmer for the outlet and you converted the original outlet into an extra return?? If I am correct, hows that working out? Do you run both returns AND the fountain at the same time? I had figured to keep the original outlet in addition to the thru the wall skimmer in order to clear some of the debris from both the surface and from below.
    You did an awesome job on this. (I love the towel rack too!) I hope you don't mind me picking your brain a bit. I can do all kinds of things, cook, quilt, paint etc. I'm in the process of building a gate (my husband is working on it too) for my wooden pool stairs but plumbing, that confuses me. I think the problem is that not all my equipment is intex. The pool is, the SWG is too, but the pump / filter is a Sandpro 75 so I have to use adapters for everything that connects to the pump/filter.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Apr 2012
    SW Ohio
    456
    vette
    i alternate returns never run both at the same time with the exception of making sure they both worked.......Mike
    i just seen you are a fellow buckeye......go Buckeyes
    Apr 2012
    SW Ohio
    456
    Taterfink
    i will take more detailed pics tomar and give better details of the process, it is very simple and i know you can do it.........Mike
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thanks. I am pretty much mechanically inclined. Have worked with PVC with my Dad years ago. Have done minor stuff on my cars (oil change, lube, tires, even changed the inner tube on my motorcycle tire among other things). Did most all the cuts and planning for our wooden gate. I can follow instructions.
    I spent yesterday evening perusing the PVC isle at Lowes and came up with only a couple of pieces that I thought would work. Mostly, I am having trouble with the concept of the connection at the pool I think because of the difference between intex and standard fittings.
    I'm pretty sure I can handle it.
    All this to say, Thanks. I appreciate you taking the time to put together the info for me.
    Angie M.
    Aug 2011
    Gainesville, fl
    53
    I want more info on the towel rack. Nice job. That is kind of what I am looking at doing.
    12"x33" Summer Escapes AG Ring Quick set 1590 Gallons (Gift for my son by Grand-parents)
    Intex Krystal Clear Model 633 2500 GPH "B" Cartridge
    I'm interested in how you were able to get a fitting threaded onto the end of the Intex factory through the wall fitting... Care to share?
    18' x 48" Intex Ultra Frame
    2650 Intex Sand Filter
    Apr 2012
    SW Ohio
    456
    Will update when I get home with details on pool and towel rack....Mike
    Quote Originally Posted by Taterfink
    Here is a thread that tells how to make the custom PVC adapters for Intex pools. I followed these instructions and used the Cantex box adapters from Lowe's and it was very easy.
    custom-pvc-pipe-adapter-for-intex-pools-t28971.html
    And here's a link to my thread of my finished product:
    my-intex-ultra-frame-16x48-build-t50136.html
    Intex Ultra Frame AGP 16'x48" 5,061 Gal with SWG 2500 GPH pump Cartridge filter
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thank you so much!
    Angie M.
    Apr 2012
    SW Ohio
    456
    Thanks Donnie I just found out I am froze for a double today and tomar
    I have changed my 20' above ground pool over to sand filter but now I have a little problem. What I need to complete my project is a replacement skimmer. And you seem to have not only found one but you have got it work with no leaks.
    you can see what I have done with my pool just need to know what type of skimmer you used and how you cut your pool with no leaks? Thanks http://youtu.be/fAQ3DoRKDGI
    Feb 2013
    Yukon, Oklahoma
    220
    Cowboylonny, excellent job plumbing everything up. I really liked your fountain....that sure gives me some ideas for my fountain that I will start on here in a couple of weeks.
    The skimmer is a Hayward SP1091LX, they are inexpensive and what most people are using to add to their Intex pools. I believe it is similar to what most of the "real" AGP manufacturers include with those expensive AGPs.
    As for cutting, I started a hole by using the old utility knife then used a pair of scissors to do the actual cut so I could get a round corner and not sharply cut on just to keep strength there so it wouldn't rip. Probably doesn't matter, but never have had any problems.
    Bob E.
  20. Back To Top    #20
    Thanks . Spring is just around the corner and I just ordered me the skimmer so wish me luck and thanks again. Ive kinda been waiting for your reply lol.
