Results 1 to 9 of 9
Thread: Salt Water Generator / vinyl inground pool help please
    Jojo4A's Avatar
    Jun 2012
    Moundville, Alabama
    37
    Hello, my pool was completed just at 2 weeks ago. I have been adjusting my SWG sanitizer output down. It has been at 60% for about a week, we had a party yesterday, lots of people in the pool. Today FC value is 12, so I have turned SWG down to 40%. ((FC had been trending down since startup of pool: 15 --> 12 --> 9 --> 8, but then now up to 12) This week we had heavy rains, so I think my CYA has been diluted out somewhat. My owners manual for SWG says ideal salt level is 3400ppm. My water looks good, crystal clear.
    Here are my numbers:
    FC 12
    CC 0
    pH 7.8
    TA 90
    CH 150
    CYA 60
    Salt 4600ppm
    Questions:
    1. Regarding FC: Is this what I need to do. Adjust the % down, or should I maybe adjust the time it runs? See question 2.
    2. My pump/SWG is on a timer. We are currently running it 8am to 8pm. If we cut the time down, would that help decrease the chlorine output?
    3. Per pool calculator, I need to lower my pH and add cyanuric acid. Should I raise pH first, then add CYA? Should I retest CYA first after raising pH?
    Joanne
    West Alabama -18x36 Grecian Sport, IG Vinyl, 3.5 - 5.5 - 3.5. ~16000 gal
    SWG. T-100 Test Kit. Taylor Salt Water Test Kit, Taylor Speedstir.
    Pentair SD-80, Pentair Superflow 1HP, PentairIntellichlor, Polaris 280
    22,553
    Re: Salt Water Generator / vinyl inground pool help please
    Since you're running at 40% I'd adjust it down to 30% and then start lowering the run time.
    It wouldn't hurt to backwash a good long time to get the salt down some either.
    After I did that, I'd add the CYA.
    Jojo4A's Avatar
    Jun 2012
    Moundville, Alabama
    37
    When is the best time to retest? If pump/SWG is running from 8am to 8pm, should I test before the on cycle or after?
    Joanne
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Test after so everything is nice and mixed up.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    22,553
    About an hour after the pump starts. It'll be at almost the lowest point then and as long as you're above the min recommended you're good for the whole day.
    Your salt looks crazy high. Is it really 4600?
    18' x 36' saltwater inground vinyl pool
    Jojo4A's Avatar
    Jun 2012
    Moundville, Alabama
    37
    ouachita, Yes, I used my Taylor Salt test kit. 23 drops to turn the water milky salmon. 23x200 =4600 (did I do it right?) Salt was added by the PB 2 weeks ago when pool was finished. Plan to follow Bama Rambler's advice and back wash a little water out
    Joanne
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    572
    Joanne, what does your SWG panel say the salt is at?
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    You can either adjust the percentage down, reduce run time of the pump, or do both to reduce chlorine production. My pool is 24,000 gallons and I have a 12 hour run time at 40% to generate chlorine levels.
    I would keep dropping it about 5% at a time and leave the pump on a 12 hour cycle until it gets down to what you want for chlorine levels.
