G
I don't think the Frog was saying you needed to do the shock process. She also wrote:kittkatt808 said:First, why do I need to shock the pool?
So unless your pool is cloudy, or you having trouble maintaining FC, no need to shock.frogabog said:Normal high and low FC is 4-8ppm.
I think Bama was confused by you calling them "pads". I am assuming that you mean "panels"? If yes then, I highly recommend them, and have them! I sounds like you pool is mostly shady? If yes, then you likely benefit from having a panel surface area around the same as you pool area.kittkatt808 said:Solar pads the ones used for heating your pool?
kittkatt808 said:Thank you thank you
I've really got my pool balanced and steady with the levels through the sites help and pool school.
I am soon going to switch over to swg but will return with questions then...
But right now one question I have is how should I deal with the pool during the rain?
Richard320 said:
