Page 1 of 3 123 LastLast
Results 1 to 20 of 59
Thread: Testing kit I have Does not test for cya
    Guest
    In verte upset that The testing kit i have Does not test for cya
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Extended Test Kit Directions
    Quote Originally Posted by kittkatt808
    Which one do you have? These test kits do.
    Guest
    I Got mine from lesie pools it's called The delux dpd Test kit
    Guest
    Re: Testing kit I have Does not test for cya
    I also notice I can't test for ch either.. Darn I didn't get the right test, or it's lacking
    Guest
    What else is needed before I swim
    This morning I tested my water that I just filled last night and added chemicals...
    8pm last night readings were :
    Fc 5
    Tc 5
    Ph8.2
    Ta 110
    Cya I just added
    This morning I'm reading
    Fc 2
    Tc 2
    Ph 8.2
    Ta 80
    The water looks no nice the kids have no idea why I haven't let them in yet they don't understand me when I say I'm trying to get balanced. My 12 yr old told me "this ain't yoga ma" ........
    Kids!!!!!
    Anyway from pool school I see I need to use dry acid or muratic to lower my ph... Add a lil bleach to to raise FC or should I just add the dry acid and see where I'm at with ph..
    What else should I do?
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    Re: What else is needed before I swim
    Add some Acid to bring your PH down. Wait for an hour, retest and if good then go ahead and swim. Add the chlorine after you are done swimming is all. No reason not to jump in. I usually swim after 20 minnutes because the size of my pool is 22000 gallons. FC at 4-5 is not an issue at all.
    Have fun
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    30,403
    kitkat,
    I merged your two threads. It is virtually always a good idea to have your posts all under one thread so everyone can see your whole "story" and help you better.
    Guest
    Thank you I was wondering if I should keep it in the same topic...
    So on my way to purchase the acid and get another testing kit... Unless there is a way to test cya with the leslie kit I have now....
    I also had another topic about switching to wsg when I have my water balanced should I start another post when that time comes
    22,543
    That kit doesn't test CYA. I suggest you order the TF-50 from tftestkits. It has all the tests you need to add to the kit you have now.
    Guest
    And so I can purchase the additionals separately instead of the whole kit over again
    30,403
    kitkat,
    There is a K-xxxx number somewhere on that kit...it sounds like you got the K-2005 which really does test for CYA. Can you find that K-#?
    Don't buy anything at all just yet.
    Guest
    Looking looking
    Guest
    I can't find anything
    Guest
    I can't find it I'm trying to upload a pic but I can't from my phone.
    The only # I see are 18-547 on the bottom.
    Then it also says lot#2133b
    Guest
    Help!! After 2 hours of putting my nutation acid to lower my ph its still at 8.2
    I put the reccommended 5.6oz as the calculator told me
    I also tested my FC and it's .5 or 0
    I just added 37oz of bleach as per the calculator should I add nore muratic acid right now
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I suspect the kit is this one:
    pH, FC, and TA. Plus they make it sound better than it is by adding BR and acid demand.
    Add the CYA test and the FAS-DPD test and it's a K-2006. But it won't all fit in the box.
    Your pH may have been much higher than 8.2. Anything above that reads the same. Give that bleach half an hour to mix, then repeat your acid addition. Recheck pH an hour after that (pump running the whole time) and see where pH is. I recall when I took over my pool, I used a 10 lb bucket of dry acid AND a gallon of Muriatic Acid to get the pH color to change!
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Sounds like the pH was higher than 8.2. Just because the kit only shows the high 8.2, doesn't always mean it's only 8.2.
    Do another dose of acid, it should show some change this time.
    Use the known amount of CYA that you added as your CYA level for now. We assume it's in there, if you put it in. Do you know how much you added? If so, pool calculator should estimate the level for you to use for chlorinating.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Guest
    I added 28 oz of cya to get my cya to 50...
    Is that the# I'm reaching for?
    I added more acid....
    Also, that's it that's the kit I have ... DO I just add the additional
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    OK, we'll call it 50ppm and you should enter that into the NOW column in the calculator. Chlorinate/shock for that number. I believe shock level is 16ppm. Normal high and low FC is 4-8ppm. At night, you'll dose to 8ppm in preparation for the next day. Prepare to lose half by the end of the day, but never fall below 4ppm. Daily/nightly dosings will prevent this. Normal loss per day is 2-4ppm depending on weather and bathers. If you routinely lose more than 4ppm but less than 5ppm, change the nightly dose to 9ppm and that should settle it.
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    18,967
    http://tftestkits.net/Single-Item-Tests-c6/ sells the FAS-DPD test and the CYA test individually.
