Thread: TA level
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    TA level
    Is the TA something to address immediately and no swimming today or can I swim today and lower it this week so it's recommended normal range by next weekend?
    Results:
    FC: 6
    CC: 0
    TC: 6
    pH: 7.5
    T/A: 180
    CH: 260
    CYA: 40
    Water temp: 82'
    Jon
    21,000 gallons, Hayward sand filter, IG, 16x32 kidney, Vinyl, Hayward Super Pump 1hp, Flow rate: ?
    jgjh151's Avatar
    May 2012
    Glenville, NY
    39
    Re: TA level
    Just saw this from my previous post:
    CH at 250 is just fine for any kind of pool. TA at 160 is a little high, but can be ignored unless CH is 500+ or your PH is going up annoyingly quickly.
    Looks like TA of 180 is OK to swim in. I should still start to lower it though right?
    Jon
    Re: TA level
    Sure, lower TA, but there is no rush. Simply lower PH to 7.2 any time it gets up to 7.8 and the TA will come down (quite slowly, but that is fine).
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Re: TA level
    Quote Originally Posted by jgjh151
    I've never had a TA lower than 225 and I've never had any trouble with my water. I add acid about once a week, maybe every 5 days. My fill water has a TA around 350, so that is why I do not aggressively attack TA.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
