Results 1 to 14 of 14
Thread: Broken pump
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Broken pump
    I'm pretty sure I broke our pump last night. I turned it off, then turned it back on within a couple seconds without letting it spin down. If I try to turn on now, it juh
    What normally happens to the pump if this is done?
    14.5K gal Plaster IGP, Intelliflo VS, EasyTouch 8, SWG, IntellipH, Clear and Clean 420 Cartridge Filter, Attached Spa, H400IDL2 NG Heater
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Broken pump
    It is generally not a good idea to make a habit of short-cycling a pump motor (turn it on-off-on repeatedly within the span of few seconds) - just something to keep in mind. With that said, it is unlikely that this one short cycle alone was the root cause of the failure if this was the only time you did this. It may have had an underlying condition that put it in a somewhat weakened state and this one short cycle may have pushed it over the edge. Two things I would check before resigning yourself to a new pump/motor are (1) The capacitor and (2) The timer switch. If it is either of these, it is an easier and cheaper fix then getting a whole new pump/motor. Unless you are experienced with electric motors and electrical wiring, I would have a professional diagnose it.
    I would try turning it on again today and see if the problem persists before going forward with any diagnosis.
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Broken pump
    Try to determine if the motor shaft will turn easily. It may be that you spun the impeller of the shaft, and it is now jammed against the volute.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Broken pump
    I tried turning it on, and it just makes a humming sound.
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Broken pump
    Quote Originally Posted by phipsi1237
    What I meant was to try turning the shaft manually. With the switch off, reach in through the pump basket and see if the impeller will turn easily with your finger.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Broken pump
    Bo said he'd try turning it on. I'll check the shaft manually now. Btw, it's a Hayward SP3020X25AZ pump with an Emerson EB809 single-speed 2HP motor.
    Thanks.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Broken pump
    It will not turn.
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Broken pump
    It seems likely that the impeller is jammed. This means you'll have to pull the motor and reattach the impeller (assuming it's not broken). With the motor off the pump, you can ascertain if the motor is good. If you're uncomfortable with this idea, you'll need to hire someone.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Broken pump
    I removed the motor. Seems as though the diffuser was jammed in there pretty good. With the motor off the pump, the impeller turns fine. I'm going to put it back on and see what happens. Anything wrong with trying to turn on the motor before putting back in the pump?
    Qwaxalot's Avatar
    Jun 2012
    439
    Re: Broken pump
    You can turn on the motor, just hold on to it tightly, there's a lot of torque there.
    As said before, it seems likely that the impeller unscrewed from the motor shaft (they'll do that with back pressure from the filter). It will have to be properly reinstalled. With a 2HP motor, there should have been a screw going through the impeller into the shaft (to lock it in place).
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Broken pump
    Everything "looked" fine, so I was going to put it back together. The plates wouldn't flush up, so I pulled it back out. Upon doing so, I bumped the impeller slightly and it became loose. I was able to unscrew it with my hand and saw that the impeller threads that screw onto the shaft are stripped!!!! Guess I need a new impeller. Luckily it looks as though the shaft threads are ok.
    Looks like Qwaxalot was correct. Thanks a lot.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Broken pump
    Picked up a new impeller from Leslie's. I know have circulation!!!! However, I now have a small leak between the motor and pump. Pressure is normal, so I'll let it circulate a while and re-seal later.
    phipsi1237's Avatar
    Jan 2011
    Tularosa, NM
    228
    Re: Broken pump
    Took it apart again to get it to seal. Wiped down all the surfaces. Put back together. Still leaking in the same spot right in the middle under the bottom. Wasn't sure if I was supposed to lubricate the housing gasket, so I did anyway. Could that be the culprit?
    Bill
    Apr 2009
    Northern Virgina
    55
    Re: Broken pump
    Did you check the shaft seal? If the impeller threads were stripped, it's possible that it cracked the ceramic surface of the shaft seal. You should be able to see this if you take your pump apart again. If you need to replace the seal, make sure you do not touch or lubricate the shaft seals. There are some good websites and youtube videos that show exactly how to do this.
    22k gallon IG Anthony free-form pool and spa with PebbleSheen finish, Pentair WFDS-8 WhisperFlo Full Rated Dual-Speed 2HP pool pump, Sta-Rite S8D110 System 3 Grid D.E. 53 sq. ft. pool filter, Raypak R406A 399K BTU cupro-nickel propane heater, Polaris 280 pool cleaner with 3/4 HP PB4-60 booster pump, Goldline Aqua Plus controller and SWG, Inter-Fab G-Force pool slide.
