Thread: Should the pressure go up?
    Jan 2011
    Huntsville, AL
    67
    I have read several posts about backwashing once the pressure goes up a certain percentage.
    It doesnt look like my pressure has gone up at all in probably 2 months.
    The only problem that I have had is a little air from return jets. I have tried everything and cant get rid
    of the small bubbles and jet hesitation. I have a ticket in with the pb. I discussed that issue in the thread below.
    Could they be related? Is something wrong if my pressure is not going up over time?
    is-a-little-air-ok-t44491.html
    16 x 32 inground with Tara Liner, 1 skimmer, 3 returns,
    1HP Hayward Super Pump
    Hayward Sand Filter
    Polaris 280 w booster pump
    Hayward SWG & Aqua Plus
    k-2006 Test Kit
    38,251
    Re: Should the pressure go up?
    I think if there is any air in the filter it can mess with the gauge readings.
    Does the gauge go to zero when the pump is off?
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    If your pool doesn't get a lot of dust in it, it's possible it doesn't need cleaning yet.
    Jan 2011
    Huntsville, AL
    67
    It does go to zero when off.
    Hayward Sand Filter
    k-2006 Test Kit
    May 2009
    Youngsville NC
    395
    In that case - don't worry about it and do a backwash if/when you close down for the season. I live in the woods and keep a pretty close check on mine.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
