Thread: How to clean inside of slide vlave
    At least once every year the slide valve attached to the sand filter "seizes". I then disassemble it and lube the o-rings or replace them. Is this normal? I noticed the inside wall of the valve has what looks like o-ring residue (only because it's black like the o-rings). Is there some way to clean the inside of the valve?
    Above Ground Pool, 15x24 Oval - 10,500 Gal,
    Hayward Sand Filter - 150lbs, 1.5HP pump
    South Central NJ
    3,192
    Re: How to clean inside of slide vlave
    A simple Dobie pad or Scotch Brite from the supermarket. You don't want to score the tube.
    Scott
    Owner of - PoolGuyNJ LLC
