Thread: Slightly Confused...
    May 2012
    Boyd, Texas
    93
    I have an intex 18'x48" ultra frame pool. I'm kinda confused about what adapter, hose and vacuum head I need/should get. I want to be able to hook it up to the intake port as I don't like vacuuming to waste or using the cheapo vacuum that came with it. If someone would please point me in the right direction it would be greatly appreciated.
    Ideally I would like something that I could swim around with and vacuum the bottom (i like swimming underwater with goggles) :P If that's not possible then what will fit the intex pole? or should I also look at getting a different pole?
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
    May 2011
    Clearwater, FL.
    446
    Re: Slightly Confused...
    Hi superman0604,
    I did have a 15'x48" intex frame pool and ran into the same problems, I had upgraded to a 1 hp 22" sand filter system.
    I did end up putting in a Hayward AGP skimmer box kit, it came with the vacuum top hat to fit in the skimmer basket and also came with the return fitting w/ eyeball.
    Here's where I posted what I did...my posts start at the bottom of page 1.
    custom-pvc-pipe-adapter-for-intex-pools-t28971.html
    Try looking through some of these posts...
    useful-links-for-fellow-intex-pool-owners-t29612.html
    Hope you find something.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Quote Originally Posted by superman0604
    Check out something like the Pool Blaster Catfish.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    May 2012
    Boyd, Texas
    93
    Quote Originally Posted by GreatCanadian
    Thinking I may go with this. Seems more expensive but by the time you figure $30-40 for hose, $5 for adapter, $15-20 for head.... Really not anymore expensive and seems to be exactly what I need.
    Jul 2011
    844
    A lot of people seem to like it. Lots of good reviews. Good luck.
    P.S.
    If you're en eBay guy you may pick it up at a decent price.
    Bestway SWG
