Results 1 to 7 of 7
Thread: REMINDER...Do Not Mix Chemicals
    plucky71's Avatar
    Apr 2010
    Michigan
    116
    Unfortunately, I was recently able to witness the effects of mixing pool chemicals together. I responded to a call for help that was caused by mixing Calcium Hypoclorite (Cal Hypo) and Black Algaecide- Trichloroisocyanuric Acid(Trichlor?) together. I do not know if water was introduced to the two powders that were mixed together in a bucket. My guess is that the powders were mixed dry, and then water was added to them. The result was explosive.
    The person who mixed them had chemical burns on his face, chest, eyes and inhalation injuries to his lungs. He was transported to a local emergency room and that is all I know of his condition.
    This is just a reminder to be careful with your pool chemicals. Never mix with other chemicals, unless the label directs you to do so. I don't know if that is ever necessary. Anyway, read the label carefully and wear eye protection.
    It is easy to become complacent when you get used to using chemicals. I always knew that the chemicals are hazardous, but it is different to actually see the results first hand. I just wanted to pass along the safety reminder. Hopefully it might save someone on the forum from experiencing their own "first hand experience".
    Outdoor fiberglass inground 15,000 gallons, Clean & Clear Plus 420ft. sq. filter, 1 h.p. WhisperFlo pump, New water cycler automatic chlorinater(not using), 1996 pool, TF-100 test kit.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: REMINDER...Do Not Mix Chemicals
    Results can be very nasty. Thanks for the reminder to everyone.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Mar 2007
    San Rafael, CA USA
    12,082
    An example of what happens when Trichlor is mixed with Cal-Hypo is shown in this video.
    plucky71's Avatar
    Apr 2010
    Michigan
    116
    Quote Originally Posted by chem geek
    Thanks for the video. I showed it to the guys at work.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    WOW.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Aug 2011
    Virginia Beach
    295
    Is this info in a sticky somewhere? Anyone else besides me think it should be if it isn't? I know I've read this before, but that video really drove the point home.
    (I just have the "new posts" link bookmarked, sorry if I've missed a sticky)
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    ALWAYS ALWAYS ALWAYS add the chemical to water............ NEVER add water to the chemical.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
