Thread: Sand sitting on the bottom
    Jul 2012
    Toulon, Illinois
    43
    As some of you know, we are battling iron in our water. Today the wife got in the pool to vacuum some of the sediment off the bottom. There is a lot of sand on the bottom from the filter. What is the best way to remove that sand? I'm assuming it happened because the filter had been moved so when we got everything hooked up it blew the sand into the pool...
    21 foot by 4 foot AGP, Jacuzzi Laser 192 sand filter, Hayward 1 HP pump, approx. 9100 gallons, install 7/15-7/17/2012
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Sand sitting on the bottom
    If the vacuum won't pick it up, try some of the suggestions in this thread: how-to-get-the-sand-dirt-from-the-bottom-of-my-hottub-t22892.html
    30,431
    Keep your questions under one thread. People cannot follow your story if you start new threads.
